Old 11-13-2012, 05:45 AM
kabirmus kabirmus is offline
Mein Auto: bmw e60
battery problem
pls what do you know about intelligent battery sensor? because my battery does not suvive 24hours.
Old 11-13-2012, 05:48 AM
Mein Auto: bmw e60
pls what do you know about inteligent battery sensor? because my battery does not last 24hours and i dont know what the problem is.
Old 11-13-2012, 10:28 AM
Phoenix1 Phoenix1 is offline
Sleeper Wagon
Mein Auto: 2008 E61
Ummm - can you tell us a little more? Like how old is the battery! When did this start? We're there any other issues before? How often do you drive - and the distances.
2014 Audi A7 Prestige E61 SOLD 10/4/13! [/B]- 2008 E61/Monaco Blue/Natural Brown/Premium/Sport/Logic 7/Sirius. Escort 9500ci, Dinan S2 Tune (378HP, 417 ft/lb Torque), RD Sport Sway Bars. Conti DW and Michelin Xi3 snows. LED Angel Eyes, Matt Black Grill. Ext warranty until 2017!!!, 67K miles. Original owner. Fanatically Maintained, BMWCCA Member. Jersey
Old 11-14-2012, 12:00 AM
Mein Auto: bmw e60
i bought a new battery 3 weeks ago after changing my car DME and CAS.
Old 11-14-2012, 05:25 PM
z0lt3c's Avatar
z0lt3c z0lt3c is offline
what does this button do?
Mein Auto: 08 535xit
The IBS is located inside the negative battery cable and sold as one unit. BMW has revised this part 3 times and is currently only selling the 4th generation version. The latest version uses a different harness pinout, so in addition to the replacing the IBS by replacing the negative battery cable, you also need the option harness adapter.
The IBS will not throw a CEL if defective but will throw fault codes into the ECU which can be read during a typical diagnostic scope. Usually a defective IBS can be identified quickly because it will throw many hundred faults when it goes bad. You can replace the IBS without any need for additional coding or updates, simple DIY task but the parts will run around $270.
When you replaced your battery, if you did not replace the IBS at the same time, you would need to have reset the IBS to properly charge the new battery. There are a number of threads on the process to reset the IBS, this is a fairly simple task w/ the right setup. If you did an AGM battery replacement, then in addition to the IBS reset you may also need to code a new amp hours value for correct operation.
