Old 11-13-2012, 07:28 AM
Chaoul1 Chaoul1 is offline
Mein Auto: BMW 528i
1998 528i Speedometer Not working!
I have a BMW 528i and the Speedometer isn't working. All I found while searching around was that it could be the ABS Sensor or the DSC Module. Are these the two possiblities? I heard that if it is the DSC Module, I can get it rebuilt. If it's the ABS Speed Sensor I'll replace that myself. Any suggestions as to what it would be?
I'm at school now driving my Jeep. The BMW is at home and I'll be home at around 5:30. I'll check and see what lights are on/off.
Will bringing it to advanced auto parts help tell me what's happening? I don't feel like going to the dealership where the rate is $150 to do a Diagnostic check.
Everything else works great. Nothing else is wrong with the car except for the Speedometer not working.
Thanks!
Old 11-13-2012, 07:39 AM
cn90 cn90 is offline
Likely bad speed sensor (mounted at the wheel hub).
Old 11-13-2012, 11:50 AM
black528i black528i is offline
Mein Auto: e90 330i
Wheel speed sensor on the left-rear wheel, see part #24 at RealOEM.
Old 11-13-2012, 01:32 PM
Mein Auto: BMW 528i
I hope so. Will a scan tool from advance auto parts being up a code? Ill look at it once I get home from school and see what lights are on again.
Thanks guys!
Old 11-13-2012, 03:38 PM
AntsE39 AntsE39 is offline
Mein Auto: E39 528iA
I dont believe there scanner can read that deep into our cars.
Anthony
Old 11-13-2012, 05:25 PM
Mein Auto: BMW 528i
I'll buy the wheel sensor and see if it works! Thanks for the help!
Old 11-13-2012, 06:49 PM
Mein Auto: e90 330i
Make sure you get an OEM one. It will save you the time and the hassle of returning the cheap one that doesn't work.
Old 11-14-2012, 11:14 AM
Mein Auto: BMW 528i
Okay so everything is good! Thanks, but I got another problem.....I have a check engine light. I got the code. It's P0319 which is a Rough Road Sensor A- Circuit Malfunction. What do I have to replace now?
Old 11-14-2012, 12:39 PM
mlnotl mlnotl is offline
Mein Auto: 528i
Hi:
My 2000 528i has been showing the Abs sensor light in the dash and now the speedometer and odometer are not working. I have had the car checked and the sensors looked at but that doesn't seem to be the problem. Could it be a short somewhere or a loose wire?
Old 11-14-2012, 01:40 PM
Mein Auto: BMW 528i
Originally Posted by mlnotl View Post
Hi:
Did you replace the Left Rear Speed Sensor? How did you check?
Old 11-14-2012, 12:41 PM
Mein Auto: e90 330i
DTC Codes P0300-P0399 are for Ignition System or Misfire in OBD II. Thats all I could find.
