E36 (1991 - 1999)
Old 11-13-2012, 08:03 AM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
4-spoke steering wheel swap
Guys,
I found a guy who's selling his 4-spoke M-Sport wheel and i want to swap my 4-spoke standard wheel out for it since my leather's starting to go. I looked on realoem and the two wheels have different sliprings and different airbags. will i need the proper slipring to put the m-sport wheel on or can i use the one that i currently have? Also i don' like splicing or soldering wires so if I need to do that at all then maybe this wheel isn't for me.
Thanks,
Colin
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 11-13-2012, 12:02 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
You'll have to do some electrical work, so if you don't like to do that sort of thing (and why would you?), I'd pass on the wheel. Save up a little longer and get a nicer wheel, like the Euro 3-spoke w/airbag.
1998 BMW 328is
1966 Pontiac GTO
Old 11-13-2012, 01:35 PM
veteran011's Avatar
Mein Auto: 97 328is
hes also offering a 3-spoke. slip ring and airbag included. maybe i'll go for that. how do i know if i want a single or dual stage airbag? does that even matter? The DIY on doug's domain made it look plug and play...
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 11-13-2012, 02:50 PM
ZeGerman's Avatar
Warm Leatherette
I think the 3-spoke wheel should work fine, since your car and the 3-spoke wheel are both OBD2. You can verify by checking realOEM if the owner of the steering wheel knows where it came from (or will provide you with the p/n on the slip ring).
It was P&P for Doug since he bought an OBD2 setup for his OBD2 car.
1998 BMW 328is
1966 Pontiac GTO
Old 12-05-2012, 11:38 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Corey aka Nacho is wanting to put my old 4 spoke m3 wheel onto his e36 328...what do i need to do to make the horn work? Iv'e searched everywhere and nothing on what I need to splice etc.
ID:	352037   Click image for larger version
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 12-05-2012, 04:08 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I have a 3 spoke euro I bought from a guy in Ireland. Never got around to installing it. Thing is, it smells like mold. I'm not putting it in my car until I can get rid of that. If I can't figure out how to clean it, I'll sell it if anyone wants it...
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
Old 12-06-2012, 08:07 AM
B1MM3R's Avatar
Jesse Moon Bayne
Does anyone know?
Jesse
2001 330i DD
