Z3 2.8 will not fire! - Bimmerfest - BMW Forums
Old 11-13-2012, 02:15 PM
Ivanhoe1997 Ivanhoe1997 is offline
Mein Auto: '97 Z3
Any ideas. My '97 Z3 will not fire at all. The only code is PO 335 which is crankshaft position sensor. This is a 2.8L engine and I have replaced both the crankshaft and camshaft sensors. It only has one camshaft sensor. It does not even try to start and the tach does not move when it turns over. Any help would be good. thanks, ic
Old 11-13-2012, 04:10 PM
wifesauto wifesauto is offline
Mein Auto: sloporsche
check for spark at the plugs
Old 11-14-2012, 02:09 PM
Mein Auto: '97 Z3
lack of fire
I found the problem. There was a chewed/ broken wire from the crankshaft position sensor. I just bought this car and found a rat's nest in the right wheel well. The mouse had chewed this wire and I probably broke it when I installed the camshaft position sensor. It was under the center of the intake. Took me days of looking for something that looked out of whack to find it. The broken wire was out of sight but I found it when I traced the cranshaft position sensor wire. Just got back from airing it out, man do I feel better. ic
Old 11-14-2012, 02:53 PM
thank you for the report back...................and an atta boy for you
Old 11-14-2012, 03:04 PM
Mein Auto: '97 Z3
Like my old girlfriend said, you aint very pretty but you so are persistent. I will get to know this car, it will just take some time. Got a top to put on now. ic
