E90/E91/E92/E93 (2006 - 2013)
Hi Guys,
I have a 2006 330i Sports Package, already changed to non-run flat tire. However, the suspension is still pretty rough/uncomfortable for my taste. Since this is my daily commute car also for taking kids to school, is there way to make the car ride quality better? I have heard that Koni FSD can improve the ride qualtiy without changing the spring on E90 sports package. How much improvement will I get by changing just the stock sprorts shocks to Koni FSD? What else should I change to make the car more comfortable and possibly raise the ground clearnace by 1-1.5 inch without buying a new car or change the rim size? Please advise. Tks. Dave |
Why, yes it can. How many miles are on your existing suspension? Don't change ride height and expect a better ride.... |
I started to tell him you'd be along shortly.
Keep Right, Except to Pass Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool." 2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it! 2004 330i ZHP Imola/NB - missed 2000 328i TiAg - gone but not forgotten BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School! |
You shouldn't tease him about his height.
Evening liftin' - got lotsa screen time avail. |
The 2006 330i sports package sedan has 65K miles on it. The sports package is a little low for me especially during parking scratching the bottom side of the bumper quite a bit. Tks.
New shocks'll make a pleasing diff. FSD's matched to BMW springs - I'd do that if I were you. Naturally, you'll be checking suspension parts for bushing & ball joint wear. Non-RFT's, def - that's the drill. |
For the past two years, I had an RS4. It was firmer, with less body roll than my 330. But it was MUCH quieter over rough pavement. I could feel the bumps, but it didn't sound like the car was crashing over them. A lot of people blame the larger rims on the rough ride. Well, the RS4 actually had 19 inch rims, one inch larger than the 330. I now have a 2009 335 with a sport package. Even with stock shocks and RFTs, the ride isn't as loud as my 2006 was. It's nowhere near as quiet as my RS4, but it's passable. And I know I can likely improve it with Koni FSDs and regular tires. I'm not sure why the ride on my 2006 was so bad. Yes, you can improve it further with FSDs (especially at higher speeds), but don't expect a miracle. Good luck! |
Thank you Spagolli94 for the info. I guess it is possible that the 2006 E90 is not as refined since it is the first year model. Based on the information, the KONI FSD may provide some improvement but definte no miracle to make the car ride like a lexus is or audi a4 which is what I am hoping for. |
BMW's good about refinement; wheels grind slowly in Munich. But good things happen at Ground Control - combined w/delrin surfaced M arms, their yellows/matched linear springs combo has eliminated pothole explosions for this li'l boy. That's linear, not progressive BMW units. Goes around a corner, too. HP Autowerks has alternative setups. . Last edited by CALWATERBOY; 11-16-2012 at 07:21 AM. |
Place CA H20 Boi & BJ together in the trunk & the ride will improve greatly.
Ordered: March 7, 2008 Built: March 17, 2008 At port: March 19, 2008 Shipped on Graceful Leader: March 21, 2008 Arrived Port Hueneme: April 11, 2008 At dealer's: April 19, 2008 Delivered: April 21, 2008
Put pillow on driver seat and sit on it
Or drive a camry for week then return to your car and smile and appreciate
06 130i 07 320i 08 E92 325i Bicycles: Giant TCR Advanced Zero, Argon 18 Krypton NEXT CAR : A PORSCHE
I am considering a move to 16" wheels on my wife's '07 328 xi wagon. From what I've read the xi isn't a real sports package so I don't think the Koni's would be the answer, and I don't think they are available for the xi. I'm struggling with the thought of non RFTs since it is the wife's car. I bought a used set of 16s today but the tires are shot so I won't truly be able to evaluate the effect of the wheel change until I replace the tires.
Why not OEM Non sport shocks and springs? IIRC the early models had progressive springs
Sent from my MB525 using Bimmer App |
That's a possibility but if he's going to swap out these components I suspect he'd find more value / satisfaction replacing them with the Koni FSDs. Even the stock non-sport suspension gives a fairly harsh ride. From what CA has said the Koni's go a long way in improving the ride (wrt comfort) over both the non-sport and sport suspension.
I would suggest finding a non-sport equipped car and doing a test drive. It will likely have smaller rims, correspondingly larger (taller sidewall) tires, the different shocks/struts and springs - in other words, it will probably be a good representation of the "best case scenario" with regard to ride quality. Two examples:
We purchased a Volvo XC60 R-Design for my wife back in March and quickly realized it was just too rough riding for us (20" rims, lower profile tires, and firmer springs/shocks were all part of the RD package on that car). We got a loaner with the base suspension (17" rims, softer shocks and springs) one day for comparison and while still not perfectly smooth it did give us an idea of what it could be "best case" from Volvo. After driving the car for a couple more months and really paying attention to the source of the rougher ride I decided (on that car) that the rear suspension was inordinately harsh. I then swapped out only the rear springs and shocks for the base suspension units which made a significant improvement. Enough so that I haven't really considered doing the fronts or swapping to smaller rims. The car does not have RFTs, but does have a comparatively heavy Pirelli tire. When they wear out, I'll be going with a set of the Continentals which weight about 4 lbs less a tire (in hopes of an incremental improvement). Prior to the Volvo, I had swapped rims on her NON-SPORT 530i from 16" to 17" with a correspondingly lower sidewall height. This worsened the ride quality, but not that much (which I was happy about). My guess is that gong to a smaller rim size might not generate as much of an improvement as you would like. In short, I'd check out the non-sport packaged cars and consider non-sport springs/struts first. You will have more wheel well gap, but there is no free lunch. |
Get slightly higher wall tires. I got 225/45/18 instead of 225/40/18. This helped tremendously. My winter wheels (225/45/17) gave me a smooth ride, but 2 sets of summer tires (225/40) gave an horrible ride on bad pavement. No wonder that BMW updated their 18" on the F30 with 225/45 profile. Much better.
Check for any sign of seepage on the shocks. If there is any, they may not doing their job. My car wasn't bouncing excessively yet there was some sign of a leak. I changed the front shocks; one of them was clearly shot. BTW, I have a lowered car and ride with the changes I just mentioned is very good.
2007 E90 AW 323i Step | Lowered 1.25"/1" | BMW Performance Exhaust | PBX | Debadged | Scangauge II | Style 162 18" & 161 17" wheels & rear 15mm spacers Last edited by Saintor; 11-25-2012 at 05:10 AM. |
I think some here are making this very overcomplicated. I say change out the shocks for Koni FSDs and be done with it.
2010 M3 E93, 2010 Porsche 911 GT2, 1969 Camaro Z28, 2013 Ferrari 458 Italia, 1964 Jaguar E-Type, Caterham Super 7 (track car), 1957 Thunderbird, 1954 Jaguar XK120, 1958 Corvette, 1955 MGTF, 1965 Shelby GT350, Superformance 427 Cobra, 1955 Chevrolet Nomad, 1965 Shelby GT350, 1963 Corvette Split Window Coupe, 2001 BMW Z8, 2012 BMW 750Lix (daily driver), 2012 Porsche Cayenne Turbo (wife's car). |
Unless you have lots of experience in this kind of stuff, do the low hanging fruit first. FSDs are great, relatively cheap, and don't have unexpected side-effects. AFTER that, if you still want more, move to the next step.
BMW CCA Member |
What psi are you running? 17" wheels without runflats at a lower psi has to help. Mine are at 35psi but might be too high - need to investigate. Certainly I doubt they need to be as high as the stock low profile runflats which are 42psi in the rear IIRC.
![]() Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93) 28 vehicles in 26 years of driving so far. Guess I like cars
CA
Drivers Club at Lime Rock The Glen Club International Motor Racing Research Center BMWCCA Cayman Club Nor'Easters Madison Ave. Sports Car Driving and Chowder Society (Only a Vice President) Sports Car Club of America Polish Racing Drivers of America (PRDA) American Mural Project |
IMO tires ( specifically RFTs ) and suspension ( shocks or dampers ) affect ride more than wheel size. Going from 16" RFTS to 18" non RFTs I noticed barely a difference in ride. Driving a loaner with sport suspension and 17"RFTs for a few days seemed fine until I got back my base suspension 18"non rft, so much more supple and smoother. While I love the look of the lower sport suspension ( jealous of you guys ) I prefer the comfort of my setup. I'd do what u did, ditch the RFTs ( if u get a flat, you're gonna call AAA anyways, who changes tires on their own anymore? Plus replacements will be so much cheaper, especially if u r getting new left and rights ), then maybe shocks? Or keep your setup and drive wifes/ girlfriends car when the family goes for a spin. My brother in law has a sport suspension and 18" non rft, but family still prefers sisters car, they say that the choppy ride gives them anxiety, oh brother!
Did you have the DWS tires before you got the FSDs? I'm considering that for my next summer tire. That, or the Pilot Super Sports (which I had on my RS4 and were fantastic). I know the DWS have a very soft sidewall and I'm worried that the ride might be too soft combined with the FSD. Thoughts?
#25
Sport suspensions are not a good match for the ravaged roads of the urban areas in the Northeast U.S. When I have to drive to Boston or NY I take the Cayenne.
2010 M3 E93, 2010 Porsche 911 GT2, 1969 Camaro Z28, 2013 Ferrari 458 Italia, 1964 Jaguar E-Type, Caterham Super 7 (track car), 1957 Thunderbird, 1954 Jaguar XK120, 1958 Corvette, 1955 MGTF, 1965 Shelby GT350, Superformance 427 Cobra, 1955 Chevrolet Nomad, 1965 Shelby GT350, 1963 Corvette Split Window Coupe, 2001 BMW Z8, 2012 BMW 750Lix (daily driver), 2012 Porsche Cayenne Turbo (wife's car). Last edited by UnderSteer; 12-10-2012 at 04:14 PM. |
