The X5 SAV Forum
Old 11-14-2012, 12:21 AM
white_lancer white_lancer is offline
Mein Auto: BMW X5 2002 E53 4.4i M62
Spark Plugs
How often should you change the spark plugs?
E61 525i 2004 M54 Auto
E46 320i 2002 M54 Auto
E46 330i 2003 M54 Sedan Manual
Old 11-14-2012, 10:51 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
Every 50k miles and/or every 2 years.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by batmobeamer View Post
So in other words **** you haha. Batmobeamer $
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 11-14-2012, 01:45 PM
ECSTuning's Avatar
Mein Auto: e30
This is the same interval I used on my old M62 powered bimmers and what we suggest to customers.
800.924.5172
OEM BMW Part Number Search
Old 11-15-2012, 12:00 AM
spark plugs
thanks guys. you can tell I'm not a mechanic!
I am looking at the OEM Bosch spark plugs with the 4 earthing points. Do you have to set the gap up these or are they pre-set from the supplier?
Old 11-15-2012, 12:36 AM
Mudnyrey Mudnyrey is offline
Mein Auto: X5 3.0i
I have used the same OEM Bosch plugs. Gap is pre-set.
Old 11-15-2012, 04:25 AM
spark plugs
What are the benefits of changing your spark plugs?
I think mine have not been changed for quite a while but the car runs very well.
Will you get improved mpg?
Old 11-15-2012, 08:04 AM
petriej's Avatar
It's possible, but if the car is running very well there's no need to change anything.
GGC BMW CCA #443004
Join the BMW CCA!
Old 11-15-2012, 09:15 AM
Mein Auto: X5 3.0i
BMW Tuneup & Maintenance Tips:
Tuneup & Auto Maintenance Tips To Lengthen Your BMW's Life
Tuneup - an old-fashioned maintenance term that's nearly non-existent today. With electronic ignition and fuel injection came computers that took over control of engine settings. Early versions allowed for some tinkering, but today's engines require advanced equipment and training.
You can, however, replace normal maintenance parts and still see improved engine performance from your BMW. Here are common maintenance parts you can replace to significantly increase performance and reduce major problems:
Basic Ignition Parts
Spark Plugs: Spark plugs are good indicators of engine condition. Removing and inspecting spark plugs tell you a lot about how well the engine is running and what may be causing problems.
All spark plugs should be removed and checked every 30,000 miles - even if your BMW is "low maintenance" - you're told to change spark plugs at 100,000 miles. This prevents the plugs from seizing in the block, causing expensive repairs down the road.
Always note which plug came from which cylinder. This tells you if a particular cylinder has a problem. BEWARE: New spark plugs can make a difference in your BMW's performance but only if replaced with the appropriate OE replacement plug.
http://www.bimmerfest.com/forums/sho...d.php?t=471358
Old 11-15-2012, 11:35 AM
plugs
I dont have a torque wrench.
Do the plugs have to be torqued down or can I just tighten them by hand.
Old 11-15-2012, 11:48 AM
petriej's Avatar
Torque down to hand tight, then another 1/4 turn. Too much or too little and bad things will happen.
GGC BMW CCA #443004
Join the BMW CCA!
