Old 11-14-2012, 06:33 AM
hubbs25523 hubbs25523 is offline
Mein Auto: 97 bmw 528i
car makes a popping sound threw the entake and will not idle
i hooked it up and got these codes p1189- fuel control bank 2 sensor 1 .....p0101- mass or volumn air flow circuit ...p0505-idle air contol system....p0335- crankshaft position sensor "A" circuit....p0420-catalyst system effenciency below threshold... p1750-senconary pressure solenoid circuit range/peformance or system voltage input low ....p0173-fuel trim....... anyone know about these and what ones i need to change to get my car to run
Old 11-14-2012, 08:05 AM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/5SC 97-528/5
I have a few questions for you.
How many miles does your car have?
Is the catalytic converter original?
Old 11-14-2012, 09:07 AM
car has 259,000 miles and idk if the catalytic converter is original but i was out messing wit my car and i unpluged the mass airflow sensor and it stays runing but idles lil ruff and when its plug in it wont stay runn ing
Old 11-14-2012, 10:25 AM
16valex's Avatar
When un-plug and plug any electrical connector always be cautioned to switch the ignition OFF.
Did you unplug the MAF while the car was running? If this is the case your ECU is going nut trying to map. You should erase all the codes and start over again and see what codes are going to come back.
If your CAT is original and with 259K miles I bet it's all clogged up, and this is the reason why you have back fired through the intake.
If I were you, it's time to shop for new CAT.
Replace the intake manifold gasket and all the hoses under it.
Replace the fuel pressure regulator.
GL
