Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 11-14-2012, 08:37 AM
montanus123 montanus123 is offline
Mein Auto: 550i sport
BMW 550i sport 2008- OIL leak
anyone know a good indie mechanic in the Red bank, NJ area .. have a oil leak and dont want to get crushed by BMW dealership
Old 11-14-2012, 08:40 AM
ArtchredTTU ArtchredTTU is offline
Mein Auto: 550i
Just wondering, where is the oil leak coming from?
Old 11-14-2012, 08:42 AM
oil leaking from alternator mounting bracket
Old 11-14-2012, 11:24 AM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
How do you know that?
BMW CCA Member, Capital Chapter
Old 11-14-2012, 10:06 AM
v8power v8power is offline
Mein Auto: 2008 550i M
On that side, I think its either the vanos o-ring seal or valve cover gasket. Check under the vanos. If it is leaking just swap it out. One bolt each.
The dependable- 2011 Acura MDX Advanced
The garage decorator- 2008 BMW 550i M Carbon Black
2013 Triumph Daytona 675R
Old 11-14-2012, 10:28 AM
so your saying i should sell this Now before many more problems start to come?
Old 11-14-2012, 11:10 AM
Jaycal3's Avatar
Jaycal3 Jaycal3 is offline
Mein Auto: 2004 545i
Hmmm... I think he said its an easy fix.
Deceased - 2004 BMW 545i Black/Auburn
-Sports Suspension, Premium and Cold Weather Package, Logic 7 Professional Audio, Rear Sunblinds, Adaptive Xenon Headlights, Active Steering, staggered setup on 124's, Aux Input
Mods
MTEC V3.0 AE's, Black and white roundels, Clear LED Side-markers, New Conti ExtremeContact DWS's, Charcoal Filter Delete, 35% Tint, 20%rear.
http://s705.photobucket.com/albums/w...%20BMW%20545i/
GARY BETTMAN IS A TOOL!
Old 11-14-2012, 02:32 PM
It is a simple fix if you can pin point the leak around the vanos.
I have thought about getting rid of mine too, but the repairs are much less than the resell depreciation value. As much as it stresses me with all the problem, it still puts a smile on me everytime I drive it.
Back on subject: parts can be found here RMEuropean.com or bimmerspecialist. Its just a couple o-ring on each vanos and a 10mm bolt on each. While you're at it, clean the vanos. Your car will thank you and in return it will provide a pleasant drive.
Old 11-15-2012, 08:03 AM
hey bud .. thanks for advice
BMW is telling me its a 7 hour job to take apart everything to get at this Gasket...
costing me 1300 .. ugh .. not what i need right now
im not too sure what to do ?
jon
Old 11-15-2012, 03:52 PM
schpenxel schpenxel is offline
Mein Auto: E60 - 545i
you could always let it leak and just keep an eye on the oil level
Old 11-15-2012, 04:17 PM
If it is indeed the vanos or the cylinder head cover gasket, there no reason that you have to bring it to Bmw dealer. Any indy can do this simply for way less. But if you plan on diy may this can help you out http://tis.spaghetticoder.org/s/view.pl?1/07/45/43. Doesn't have 550 but the 545 is pretty similar. GL
