Old 11-14-2012, 02:07 PM
xchudyxpl xchudyxpl is offline
Mein Auto: 2002 530i
Engine fail safe
Hi, guys
Here is the story in the nut shell. Today I replaced MAF sensor on my 2002 530i with the cheap aftermarket part ($30). After the replacement SAS light went out. After driving couple of times everything was fine until ENGINE FAIL SAFE appeared and cars throttle was not responsive at all.
Here are my thoughts:
I know that electrical parts should be OEM (times are hard wanted to save money)
The engine fail safe went off after I restarted the car.
My prediction is that the new aftermarket MAF sensor is throwing off the computer and causing this mess.
Please advise, I still have the original MAF sensor which I can put pack any time.
Is there any danger with having aftermarket MAF sensor installed?
Please advise.
Thanks,
Paul
Old 11-14-2012, 02:14 PM
Psalm11_6 Psalm11_6 is offline
Mein Auto: 98 540iA Sport
Out of curiousity, which brand did you go with on the MAF?
I would say it's unlikely that you're going to cause lasting damage simply by cheaping out on this particular sensor. It CAN (and likely will) adversely effect the performance as the MAF is used to help determine air/fuel mixture ratio. I don't have any experience with janky MAF's, but I'd imagine there's a high probability of running either richer or leaner than expected, either way resulting in some overall oddities (depending on HOW rich or lean it gets).
Old 11-14-2012, 02:23 PM
There is no brand I purchased the sensor form e-buy (Chinese of course).
When it comes to engine fail safe, it never happened to me before. With that being said this happening in the same day when I changed the sensor seems a little odd. That's the reason I started the conversation in order to get some feed back.
Possibly share of similar sympthoms.
Old 11-14-2012, 03:17 PM
Any ideas guys?
Old 11-14-2012, 03:29 PM
moots's Avatar
moots moots is offline
wat's dat noise
Mein Auto: '97 528i
try putting back the original maf sensor and see if the sas comes back and engine fail safe goes away......if they do then it's the crappy $30 sensor.....
Fuelly
Old 11-14-2012, 03:37 PM
I will see what happens tomorrow. My only concern is while the cheap MAF sensor is installed can it cause any damage to the electrical system or what not?
