E46 (1999 - 2006)
Old 11-14-2012, 04:11 PM
KenN KenN is offline
Mein Auto: E46 330XI
Car is having a hard time to move when cold
Since the weather gets cold, usually under 45 degree. Every morning, my 2001 E46 is having a hard time to move fordward/reverse eventhough I try step on the gas, and the engine is revving. This would only last for 5 mins and everything becomes normal. No faulty code or light. The car has 112k on it. Is anyone here having this issue? How do you fix it?
01 E46 330XI[SIGPIC]
Old 11-14-2012, 05:05 PM
Siskin's Avatar
Siskin Siskin is offline
Device Under Test
Mein Auto: '04 325xi
So, to clarify, this is an automatic? When you apply throttle, the engine responds but the vehicle moves at a slower pace than normal?
Have you checked your ATF level?
Siskin | 2004 BMW 325xi ZPP/ZCW
Enough miles to make it to the moon... Here's to getting home.
Old 11-14-2012, 05:09 PM
This is auto transmission. I have not checked ATF level. Thx for reply!
Old 11-14-2012, 05:15 PM
Siskin's Avatar
Device Under Test
I would start by checking the fluid. ATF is not a dual weight oil and will not circulate as well at colder temperatures. If the fluid level is good, it may still need a change. Any contamination can influence the viscosity.
BMW says the fluid is good for the life of the vehicle, but c'mon, man... that's why these trannies grenade themselves at 200k.
Old 11-14-2012, 05:17 PM
halltristan's Avatar
halltristan halltristan is offline
Bimmer Enthusiast
Mein Auto: 325i and X3
You have a vacuum hose leak. It isn't the transmission. The fact that the car doesn't have any trouble after it has heated up is the key. I had a Suzuki that did the exact same thing. You probably have a vacuum hose with some holes - as the car heats up the hose expands and self seals. Good news is, this shouldn't be an expensive fix. The bad news is you or a mechanic may have a hard time finding the leak.
Member No. 470379
