X3 E83 (2004 - 2010)
Wheel / Tire experts here?
I recently lucked out on a find from Craigslist.
Found 17" wheels for my snow tires that apparently used to be used on a BMW X5. Center bore is a match, along with bolt pattern. (They are not BMW wheels, though they look similar to the early X5 model 17" wheels) The differences are what I'm curious about. Instead of my stock wheel size of 17x8, they are 17x8.5 and the offset is et43 instead of et46. The offset doesn't concern me, however the slightly wider wheel shows a noticeable decrease in my sidewall flex since it's stretched over slightly. What I am curious about is whether this is a problem (though I doubt it is?) and whether or not my tire pressures should be lowered slightly for the increased sidewall stretch? I tried looking through Google, but not sure how to sift through the wealth of hits to drill down to the info I want. Last edited by Wongway; 11-14-2012 at 09:36 PM. |
Check out:
http://www.tirerack.com/tires/tirete...jsp?techid=198 The 8.5" wide X5 rims are within spec. for 235/55/17 tires, but at the upper limit. I don't think you need to run decreased psi. |
Sorry, I wasn't asking about a wider tire. I was asking the effects of a wider wheel on a tire.
Thanks a lot everyone for pointing me in the right direction! |
2013 S4 Loaded (and NO RFT's) Awesome is an understatement 2008 MT X3 2007 AT X3 RIPOS ![]() 2005 GC 2000 Jeep Cherokee 1997 Twin Turbo RX-7 1984 GTI Wolfsburg Edition Neuspeed and more |
During winter time you dont want a "wider" tire.
![]() #465420 National Capital Chapter My Progress Thread 2000 323Ci | TiAg | Gray | ZSP | ZPP | AFE | UUC | Eisenmann | Koni | ACS Type III | Coby Wheel | 330 Brake Swap w/ BMW Performance Rotors 2006 X3 3.0i M-Sport | Silver Grey | Terracotta | Navigation | Premium Pkg | Cold Weather Pkg | AFE | |
You could run a 235/60r17 size tire if you want more sidewall. This is the size I use for my summer setup.
I wouldn't go below 29 psi on the front tire pressures and 32 on the rear as per the BMW manual recommendation. Even a 225/65 r17 can work for a skinnier and taller tire. This is the size I use for my winter setup. I should clarify that I'm using 17"x8" wheels. Also, if you search on Michelin's website for example, it will show the safe "rim width" for each size tire under specifications. If I look at Michelin Pilot MXM4 in 235/55r17 size it shows the safe rim anywhere between 6.5" and 8.5"
