I know these cars are pretty rough on rear tires, that's how they get the handling they do out of a car of this size / weigh, but can't recall what the normal wear pattern is.
Your tire wear is completely normal. The car is set up with a far amount of negative camber. It's how BMW makes a 4000 lb car handle like a dream.
You can take it to your alignment specialist and tell hiom to set it to the least negative value and still be in spec. The car won't handle as well but I suspect you won't notice.
Ditto. I think that it is around -2 degrees camber for stock. You can usually get another degree toward 0 out of the stock camber adjustment. I don't plan on going more positive than -1 degree. I am in the same boat. I won't likely notice the decrease in camber, but my wallet will notice even more. :thumbup:
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
