E90/E91/E92/E93 (2006 - 2013)
Old 11-16-2012, 07:11 AM
4EST 4EST is offline
Mein Auto: E90 318d LCI
E90 N47 engine vibrations
Hello
I've got some engine vibrations when running idle. Not sure if engine should vibrate like this or not
The vibration's frequency is quite high, hard to capture on video. Instead, you only see the engine cover moving slowly in the video. But in fact it vibrates very quickly
When removing the cover, the engine itself vibrates even quicker, so on video it looks still.
I wonder what the cause might be and where to start looking for it.
Old 11-16-2012, 08:02 AM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d
Originally Posted by 4EST View Post
... I've got some engine vibrations when running idle. Not sure if engine should vibrate like this or not
No M47 engines here in the USA, there are a few UK guys here. Have you posted on the UK site?
But, I don't think there's anything wrong with the engine itself. 4-pot engines are rougher running than i-6, and it looks and sounds pretty much normal.
Two things I can think of to check:
1) Engine mount may be broken; this would cause engine vibrations to be not damped. However problems with them usually are apparent while under load (on road).
2) I believe that the M47 has a mass damper (counterweight system) to smooth vibrations of the I-4. However, it's gear-driven and I think if it failed the engine might not run...
Old 11-16-2012, 08:14 AM
thanks for the suggestions. BTW, it's N47 engine (next evolution)
I don't think engine mounts might be broken, maybe loose
Mass damper could be, milage is 177.000km
Maybe it's normal and I'm just paranoid
Old 11-17-2012, 08:10 AM
Roleez Roleez is offline
E60 to E90 to E92
Mein Auto: 2011 E92 335i M-Sport 6MT
Two things are the causes for your concern:
1. Engine cover isn't secured completely (reinspect all rubber mounting grommets under the cover and their metal contact points on the engine)
2. The engine has four cylinders
2011 BMW E92 335i 6MT (Space Gray/Coral):
Premium / M-Sport / CA / PDC / Navi / Rear Shade / Rear Fogs / HK Logic7 / InvisiGuard Film / Dinan Exhaust & Pedals
2006 BMW E90 330i 6MT (Sparkling Graphite/Terra): retired
2008 BMW E60 Dinan M5 SMG (Indianapolis Red/Black): retired
2006 BMW E60 Dinan 550i 6MT (Titanium Grey/Auburn): retired
Old 11-17-2012, 09:03 AM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
The 320d has a known issue with failure of the front pulley assembly, which includes a mass dampener. I am not sure if this also applies to the 318d. The problem was mostly for Diesel E46 models, but apparently some E90 models also had this problem. Anyway, you may want to get that checked.
Alpinweiß
E46, E83, E90 (all with three pedals)
BMW CCA member
Old 11-17-2012, 12:43 PM
Roleez: 1 - will do that; 2 - indeed, I have some empty space at the front of the engine, I guess I'm missing 2 cylinders
alpinweiss (my favorite bmw color): I red about E46 problem with mass dampner. I think it can be inspected visually from under the car, right?
Old 11-17-2012, 07:35 PM
...alpinweiss (my favorite bmw color): I read about E46 problem with mass dampner. I think it can be inspected visually from under the car, right?
Thank you for the compliment.
Yes, you can see the engine pulley and vibration damper from below. You will have to remove the protective cover underneath. But I am not sure if you will be able to see if it has failed, or not. Obviously, if the rubber has completely decomposed, you should be able to see it, but if it is a fine crack, it may not be as easy to see. You may have to physically test the damper.
Here is a picture: http://www.realoem.com/bmw/showparts...85&hg=11&fg=18
Once again, this was more of a problem on the E46 320d cars, so I am simply guessing about your car.
Alpinweiß
BMW CCA member
bmw n47 engine vibrations
