X5 E53 (1999 - 2006)
The X5 SAV Forum |
2006 BMW X5 headlight problem, please help:(
hey guys, my left side headlight wont't turn on unless i unplug the right side headlight for few seconds
. why is it doing this and what is a possiable fix? and also it would be a good help if someone could tell me where the headlight relay/fuse is . THANK YOU!.
Can't help you with the first question as I'm new to the e53 (approx 1 week) so there's lots of common issues I'm just learning about.
But the 2nd question is easy to answer due to BMW using the LCM/LKM (lamp/light control module) for decades as the controlling unit for all exterior lighting. There may be a fuse or 2 that support the LCM/LKM...I'd look at the fuse index in the glovebox and the rear cargo area for that info. There should be a fuse diagram that has all the fuses listed alphabetically along with their fuse nbr...along with an illustrated diagram of the fuse box with each fuse location nbr listed along with the fuse's amperage. ![]() ![]() ![]()
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
I have noticed a delay in the illumination of my passenger headlamp from time to time. I expect that may be a (mal)function of the LCM as well.
_________________________________________________ 2006 X5 4.4 / 1972 2002 / ret. 1998 328is / ret. 2002 330ci |
| Tags |
| headlight problem |
