E36 (1991 - 1999)
Old 11-17-2012, 10:38 AM
sejen sejen is offline
Mein Auto: 328i 1998
E36 Rough Cold Start and bad O2 sensors
Car will start but runs very rough until warm. Large amount of blue smoke on initial start up. How much effect does bad O2 sensors have during cold weather start up (30-40 degrees F)? Car has had history of very small head gasket leak, which has caused the O2 sensors to fail. Do not want to change O2 sensors (again) until I am certain head gasket leak is resolved. (Not trying to get into a big head gasket discussion. I checked compression with very good results, not mixing fluids, no overheating, used approximately 12oz or less of anitfreeze during last 2500 miles. Please no comments about head gasket.) Just would like to know if there is some other major reason car would run so bad at cold start up. Blue smoke may occur with warm start up but car does not run rough unless cold weather. Replaced spark plugs with correct BMW plugs recommended by BMW mechanic. Blue smoke stopped on start up for about 2 weeks. Changed the plugs before cold weather become a issue, so not sure what effect plugs had on cold weather start.
Old 11-17-2012, 11:04 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
well, without mentioning the headgasket....
blue smoke is an indication of burning oil, which points to either valve seals or rings. either way, the oil burning will also kill the o2 sensors.
df
Old 11-27-2012, 06:32 AM
Thanks for the reply
Old 11-27-2012, 10:59 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I'd check the gasket that sits between the block, and the part of the engine where the valves hang out. I forget what that part is called though.
The intake and exhaust manifolds bolt onto it.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
