Passenger seat stuck in rear position
Have visited forum many time to help in repair issues. I have encountered a problem that I have not seen posted before - 2001 e39. The passenger seat was moved rearward and will now not move forward. I can remove the seat because it is stuck in the rear position with the seat over the bolt. I have determined that the switch module works -checked continuity. So I believe that something is either jamming the rail or the motor is no longer working. I think I would be able to diagnose the problem if I could get the seat out. Any ideas?
I assume you've checked the connectors behind the finisher where the switches are mounted, and those under the seat.
Do any other seat functions work?
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
All the other seat functions work with there switches. What little wiring I can see under the seat seems to be in order. The one connector to the drive motor near the door is in place.
