Slight coolant leak... Where the heck is it going? - Bimmerfest - BMW Forums
Old 11-21-2012, 06:20 AM
gtxragtop's Avatar
gtxragtop gtxragtop is offline
Mein Auto: 2003 530IA
My 2003 530 has had a slight coolant leak that got worse after a cooling system overhaul. It looses about 3-4 ounces every 3-4 weeks. I've looked at all the hose connections, water pump, expansion tank and cannot see any telltale signs of leakage. Never see any visible seepage. Anybody have any suggestions? I wonder if I may have a heater core issue but I never smell coolant nor do I get any telltale residue on the windshield which I've known in other vehicles to indicate a heater core leak.
Any easy way to visually check the heater core without removing the entire dash?
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
Old 11-21-2012, 08:36 AM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
Did you check for leak around the water pump?
One other place that has been known for leak is the lower radiator hose sensor.
Old 11-21-2012, 09:03 AM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
you could remove side panels and look or smell for leak
www.540i6.com they all do that FSU. In the write up it show you how to carefully remove carpeted side panels. Is there any coolant in the splash panel under the engine?
Old 11-21-2012, 09:47 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
If the heater core were leaking, you might have a soggy carpet, and the smell of coolant when the heater is working.
Old 11-22-2012, 05:59 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Well, guess your going to have to drive that Mopar around from now on--that 440 should still jar the ground and pull a little better that the BMW anyway.
I don't know how many miles are on the car with the seepage problem or how long this has been going on. Take this into consideration though--I have many freinds that have worked as mechanics for all their lives and they are asking from time to time the very same thing your asking now--where the hell is the coolent going--this happens to lots of different brands of cars and from what I think and some of me buddies that it has to be internally leaking. Now don't know about useing cheap stop leaking snake oils that are out there and could plug up internals--but there are high dollar liquids that work well and that I would trust, just throughing that out there in case you haven't as yet thought of it--best too you and yours at Thanksgiving
Old 11-22-2012, 06:06 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
You could do a pressure test on the cooling system and look for an external leak while the system is pressurized.
Also have the coolant checked for traces of hydrocarbons, this would indicate coolant is leaking past the head gasket and into the cylinder(s).
2000 540/6 Slightly tweeked...everywhere
Old 11-25-2012, 07:51 AM
gtxragtop's Avatar
Hey poolman,
Can't drive the Mopar in the rain or winter. She has all original sheetmetal with no rust and there is only one way short of moving to AZ in New England to keep her that way... Stay out of the elements.
I've been worried for awhile now about some sort internal leakage. When I replaced the cooling system I pressure tested the system overnight at about 15 PSI (1/2 of the normal operational pressure) Well in the AM there was a pound lost but I figured that perhaps the hoses expanded a bit, temp dropped etc. Then went I went to start it, it would not fire for quite a while. When it did it ran like crap like cylinders were misfiring. After about 30 seconds it settled down and was fine. That was over 50K miles ago. Otherwise it runs flawless, gets great fuel mileage. I have this nagging feeling that this is related to the coolant loss.
Any suggestions on a top quality sealer?
Old 11-22-2012, 08:48 AM
vavet5308 vavet5308 is offline
NADAVAN
Mein Auto: 2002 525it
Did u change the pressure cap during the cooling system overhaul?
Sent from my PC36100 using Bimmer App
Old 11-25-2012, 07:54 AM
gtxragtop's Avatar
No, but no leakage seen around cap. Usually one would see a white dust like residue if a leak was present. For a long time I had a bitch of a time sealing the 1/2" top hose to the barb on the expansion tank. I finally got this to seal. I just checked this again and no residue there so I'm confident that this is not an issue.
Old 11-25-2012, 08:58 AM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
The issue might be cap not releasing pressure, causing too high pressure and coolant to leak else where. Its recommended to change cap with the expansion tank, given the low cost.
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 11-25-2012, 10:16 AM
Fudman's Avatar
Fudman Fudman is offline
Dave:
Your loss of pressure suggests a small leak somewhere in the system. I would not put any aftermarket crap inside the engine. It's not worth the risk of causing unanticipated side effects. Better to just check the coolant level weekly and top off. Keep a gallon of coolant in the trumk and your are good to go.
Old 11-25-2012, 10:34 AM
oltom oltom is offline
Mein Auto: 530i
About your start up after the overnight pressure test with pressure drop. Any white smoke out the tailpipe? Of course if your driving a mopar classic I'm sure you know where I'm going with this.
Did your antifreeze fluid consumption/loss rate increase during the period of time after pressure test and the running unstable period? Motor ever been overheated or run on the hot side, but still in limits? No need to reply just food for thought in the the even you haven't gone down that road already.
Old 11-26-2012, 05:36 PM
gtxragtop's Avatar
White smoke; Not that I can remember but I was more worried on what the heck was going on at the time.
Increase after pressure test; No
Overheat; Never since I've owned it as a CPO at 52K miles. Temp Always runs right in the middle. Could something have happened with the previous owner? Possibly but my dealer did give me a copy of all service history on the car and nothing other than maintenance service wiper blades dead bulbs, showed up. Overall quite clean hence I bought it. One owner car, not leased.
Perhaps I'll pressure test it again and see what happens. Part of me does not want to know. What does seem to be clear is that combustion gases are not leaking into the cooling system nor is any oil. I do not see any antifreeze in the oil either.
I was thinking of buying a UV dye and see if I can pinpoint leaks from that.
Old 12-05-2012, 02:34 PM
SpartanGA SpartanGA is offline
Mein Auto: 2007 550i, 2011 335i Vert
I had a small leak and it was the sensor on the radiator. Coolant would disappear but had no idea why. Indy shop found the sensor as it is typical.
Jim
2007 550i Sport - White - Tan
Old 12-05-2012, 02:58 PM
Mein Auto: 530i
Thanks for the feed back on the Radiator sensor. I've got a small leak from under the forward lower engine cowling. Haven't had time to look into it. I'll make sure I start there and save myself some time.
Old 12-06-2012, 08:05 AM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 02 530, 02 540, 07 525
BMW's don't leak, they just mark their territory.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 12-08-2012, 11:23 AM
bagodonuts68 bagodonuts68 is offline
Mein Auto: e38 750iL
be cautious about pressure testing the cooling system on our aging cars. another post (somewhere) mentioned a suspicion that it was pressure testing (not the salmon) that brought the demise of his heater valve.
