BMW Coding and Programming
Discuss coding options and features on your BMW here. |
Generating Routes in Google Maps for uploading into your BMW Nav System
Google Maps is a better and more efficient tool to generate routes than the BMW Navigation System. You have the flexibility to change routes as you wish and select specific roads from point A to point B. The attached manual (and program) describes how you can generate trip files that can be imported into your BMW Nav system. This is possible thanks to the great programing work of our fellow fester, Aussie40d, from the E70 forum. Enjoy.
JEG23 Google Maps to BMW Nav.pdf Convert Google Maps and Google Earth to BMW V1.0.3.xlsm.pdf Remove .pdf extension
2011 550i Space Gray /Black Nappa, Dark Wood ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR Last edited by JEG23; 01-23-2013 at 07:10 AM. |
I look forward to seeing you solve the POI import next.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
I've verified that this works on an 2012 F30.
Are there any plans on making this work with more than 1 destination? I created a 3 stop trip in google maps, but when I imported the trip, only the start and first destination were imported. Sheet 2 (temp worksheet?) shows all destinations (read from the KML), but they don't seem to appear in the final XML. Also, I tried to look at the VBA code, but it's password protected. Is there a reason for that? Thanks for the hard work on this!! I had tried previously to do just this kind of thing, but ran out of time. |
@FrogmanF30,
Thanks. I suppose that is the next stage of this, capability for multiple destinations. PM me for details. JEG23
2011 550i Space Gray /Black Nappa, Dark Wood ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR |
Juan, thank you for this great tool... It's working great here in Malaysia... Simple tool, yet very useful! Thank you, Sir.
JEG23
Yes, it has the feature... But, mine is a UK spec'd car... So, I'm not sure whether a Malaysian spec'd car has this as standard...
@Jeg, did you also look at NAVI_DEST_IMPORT, which is supposedly "Asia Only"?
I am wondering if we can import an address from USB, similar to how Google Sen-To-Car works, and then Navigate to that address.
I have not tried this yet (maybe somebody can beat me to it before I get home), but if you only input a destination in Google (not a point A and a point B), save it to "Maps" and then generate the KML file, it will also be processed by the program and generate a one point place that could probably can be imported via "Import Trips" without any additional changes to the car coding. It is of course easier to do this via the Google send to car function, but it might be convenient of you want to upload multiple destinations in one shot. If that does not work I will try the "Asia Only" code that you suggest. JEG23
The Google Send-To-Car, and NAVI_DEST_IMPORT would instead use the built in BMW Navigation for Routing. Since Google Send-To-Car requires a BMW Assist account, many users can not use it, so I was thinking instead they could maybe use NAVI_DEST_IMPORT in its place, that is if it is possible for it to work on non-Asian vehicles despite what it says.
Yes I see your point. On the other hand, with a single destination, I do not think (I am speaking out of ignorance here since I cannot test that at the moment) there is technically no routing, just a destination. I do not know if "trip import" will work with that file. If it does, then the NAVI_DEST_IMPORT is not necessary, otherwise it surely is worth trying it. JEG23
I had to code NAVI_TRIP_IMPORT before I could import a trip. The comments for this variable do not indicate any regional restrictions. Only the NAVI_DEST_IMPORT/EXPORT say Asia only.
I expected that since you are in the US. Our cars do not have the "trip import" function on by default. In most of Europe (I think) and for example in Australia, this function is activated. I think in some Asian countries (please let me know otherwise), maybe they cannot do the "Google Send to the car" by default. Have you tried to generate a KML file with only one point and then import that via the "trip import" feature? If not I will try this tonight. In addition to generating trips via Google Maps, it would be useful to have multiple destinations in an USB that can be easily imported to the car. If that does not work then we should try (as Shawn suggests) the "Asia only" destination code and see if another import menu item shows up. JEG23
2011 550i Space Gray /Black Nappa, Dark Wood ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR Last edited by JEG23; 11-28-2012 at 11:16 AM. |
Awesome tool, thanks. Please keep us updated in this thread as I do not frequent a E70 forums.
Trips and Pieces - My new blog for Travelers by Travelers! Personal Euro Delivery Blog ![]() ![]() My, somewhat outdated, BMW Euro Delivery of 2009 blog with pics! |
I can confirm that this works for an E90 also. When I did European Delivery I took a USB drive with specific routes on it in hopes the feature would work (some had reported success on an ED vehicle and some did not). The option to import was not even in the menu (good thing I had a backup plan). Over the weekend I used this thread and found NAVI_TRIP_IMPORT in CIC, made it aktiv, saved it back, and now I have the import from USB option in the nav. I'll definitely be taking my laptop with me on the next ED trip to enable this.
![]() It may already be known that it works for E Series cars but in case someone searches and comes across this thread I thought I'd add the info.
2011 E90 M3 Sedan | BMW Welt Delivery on 09.20.2011 |
Thanks for letting us know it also works for the E90. I find it myself very useful. The BMW navigation system likes to send via routes that I do not like. This lets me decide how I want to get to my destination. JEG23
Check this (Europe):
https://www.bmw-routes.com/uk/en/plan-routes/index.jsp Last edited by Mobileum; 01-23-2013 at 12:31 AM. |
JEG23
Check this
Structure like: ---- is the folderstructure, : is the file to be placed in folderstructure, usbstick ist your USB Stick Usbstick: mytrip.zip Usbstick----BMWData----Nav: mytrip.tar.gz Usbstick----BMWData----Navigation----Routes: mytrip.tar.gz hint: on my F11 build in 9/2011 (German Version) it works. Mytrip.zip: pack the entire structure above in a named zip file named exactly like the tar.gz, here mytrip.zip and put it in the rootfolder of your USB Stick. According to many posts, the folderstructure BMWData/Nav should do the trick, but with the mentioned bmwroutes.com method and saving it to Desktop it creates the above structure. Try if that would work for US purposes as well! Cheers EB |
won't let me download the pdf in the first post, is link dead?
Losco,
Try it now. Remember to remove the .pdf extension from the .xlsm file. JEG23
Thanks, download worked, but realized didn't have excel on this PC lol. will test it tomorrow and see if it works on japanese nav too.
Hi JEG23,
Sounds great :-) glad that this works now to have more trips planned and executed with the BMW in the US as well ! Hope many can use this now, although a bit of handwork is needed.. But we are in a coding Forum anyway:-) Greetings from Switzerland! EB |
#25
Which method to chose.. Everyones choice
There are few things to keep in mind:
If you have BMW Assist: - then you may plan your trips in googlemaps and send it conveniently to your car If not: You cannot send your trip via googlemaps to your car and need to use one of the methods. My method supports directly multiple destinations in a trip through the tyretotravel software, and with the structure I described, at least a europe model 9/2011 can cope with the data. The raw xml from #1 was not recognized on my car. Bmwroutes.com works apparently only for europe and couple of countries, so limitations are there, gadgets like adding pictures to your trip and descriptions makes this way sweet:-) Everyone may choose and would be good to have feedback in which countries, with which modells and build, one or the other method is favourable. EB |
