X3 E83 (2004 - 2010)
X3 06 taking little longer to start.
Hello Everyone,
Hope everyone had good holiday ![]() My X3 is taking little longer to start. It not battery problem and its not stater problem because there are no signs of that. Does that meen I need tuneup? You think it could be because it time for new spark plugs? It has 60k mils. Thank you in advance. Yaz. Sent from my HTC ONE using Bimmer App |
its just cranking a little longer before it fires up?
![]() #465420 National Capital Chapter My Progress Thread 2000 323Ci | TiAg | Gray | AFE | UUC | Eisenmann | Koni | ACS Type III | Coby Wheel | 2006 X3 3.0i M-Sport | Silver Grey | Terracotta | Navigation | Premium Pkg | Cold Weather Pkg | AFE | |
Hello
Thank you for your reply.
Yes ...just the way you said, "its cranking a little longer before it fires up" Thank you. Yaz |
If that improves it then it's likely just the check valve in the fuel pump allowing the fuel system to depressurize itself overnight. It's really no big deal if that is what it is. Just pause between on and start. Sometimes it will clear itself of whatever is causing the leak and go back to normal. |
Also, does it feel slower to crank? like the starter motor turning slower than usual? it could also be the battery letting you know it's on its way out...
"If everything seems under control, you're just not going fast enough" -Mario Andretti. ___________________ River City Bimmers Chapter 2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta. 1995 ///M3 Coupe, Lux, MT, Htd seats, Cosmos Black on Black. |
I tend to do the same on my X3.
I started to do it on my e46 as well but only after leaving it for a couple days without a start.
Am going to try that for few days and see if that will work or its the battery.
So for sure its not a spark plugs right? Thank you everyone ![]() Sent from my HTC VLE_U using Bimmer App |
You might want to run a bottle or two (one at a time) of Techron through it and see if that helps. |
Same here
Ours always has requred more cranking than I felt should have been required. I recently read a thread here regarding waiting a couple seconds after turning the key to position 2. I usually wait until the dash lights start turning off (maybe 3 seconds) and it works for me. Can't tell you why though especially in your case where it was cranking immediately apparently and then all of a sudden it wasn't. Techron, different gas nor a new starter (obtained under warranty) had any impact for me.
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired |
