Old 11-28-2012, 07:05 AM
OGIEVA EMOKPAE OGIEVA EMOKPAE is offline
Send a message via MSN to OGIEVA EMOKPAE
Mein Auto: 5401 E 39no
Exclamation ABS and traction lights on on E 39 540i
I had my car go in for an alignment check then I noticed the Abs and traction light was on afterwards
It turns out one of my Abs speed sensors was bad and so I had this replaced, but After this replacement, the light goes off but when I step on the breaks there is a (pulsing) vibration coming from the break pedals along with a transmitting sound as if the break dics is dented or damaged which is not the case...however when I speed up the traction and Abs come alight again and all the vibrations and noises stop on the application of the breaks this occurs when the traction and ABS lights come on
please help...I am confused
Old 11-28-2012, 08:29 AM
It turns out one of my Abs speed sensors was bad and so I had this replaced, but After this replacement, the light goes off but when I step on the breaks there is a (pulsing) vibration coming from the break pedals along with a transmitting sound as if the break dics is dented or damaged which is not the case...however when I speed up the traction and Abs come alight again and all the vibrations and noises stop on the application of the breaks this occurs when the traction and ABS lights come on please help...I am confused
Itshardtoreadyourtextbecauseyoudon'thaveanypunctua tionandImightaddthewordisspelledbrakeandifyoudon't knowthatthenyoumightnotunderstandwhatelseIhavetosa ytohelpyoubutIwouldsimplytestallfourwheelspeedsens ors.
youcanfindthetestoverhere:
- How to test wheel speed sensors (1) but take note on why the 5-minute ABS DIY quick test doesn't always work, especially on brand new non-OEM wheel speed sensors, by Quick99Si (1)
Old 11-29-2012, 04:58 PM
540iman's Avatar
540iman 540iman is offline
resident, old fart
Mein Auto: 2002 540i sport
great runners-not punctuation! reading skills only so so, but I can't read a word of Nigerian so she is pretty darned beyond here comfort zone :-)-
Old 11-30-2012, 07:41 AM
@540i man.
I had my car go in for an alignment check. After which I noticed the Abs and traction light came alight.
As it turns out one of my Abs speed sensors was bad, so I had this replaced. However after this replacement, the light goes off as it normally should, when you start the vehicle.
But when I drive and step on the brake, there is a (pulsing) vibration coming from the brake pedals along with a transmitting sound as if the brake rotors were dented or damaged which is not the case.
However at speed up to 60kmph traction and Abs come alight again, and thereafter, all the vibrations and noises stop when I apply the brake. Everything seems normal when the traction and ABS lights are on. (but this is an indication that the ABS is not working). Any ideas or do I need to do a fault reset ?
Old 11-30-2012, 08:24 AM
Thanks for the punctuation.
What I suggest is a free test that is explained here:
- What is the cause of severe shuddering while slow speed braking on bumps (1)
That's a long thread, so I'll summarize that all you need to do is disconnect the ABS control module harness (pictures galore of which are in the post I previously referenced).
Let us know if simply disconnecting that harness has any effect on your brake-related vibration or not.
(Bill, I hadn't noticed the Nigerian connection ... all I ever get from Nigeria are badly spelled emails imploring me personally to temporarily store millions of dollars in new-found gold for them while they work out the details with the government, keeping half of the gold as their token of appreciation for my troubles) ... but punctuation should be the same in Nigeria as in the USA, right?)
Last edited by bluebee; 11-30-2012 at 08:27 AM. Reason: Added picture to help the OP locate the harness.
Old 12-01-2012, 07:22 AM
540iman's Avatar
resident, old fart
Just FYI...I am helping him through PMs. Being from Nigeria, Christmas time, pay it forward, and all that! I will stay with him and his issue through resolution. Biggest problem is finding out his level of experience with multimeters, quality of indies, etc.
Old 12-02-2012, 03:28 AM
Thanks! I'll beg out as you were the guiding light on all the ABS control module & wheel speed sensor advances we've made in the past few years.
Old 12-02-2012, 11:25 AM
540iman's Avatar
resident, old fart
Bee, funny and off topic, but I am so naive about scams since you brought up the one about all the money left you, etc. What is the "jist" of the scam where they want to pay you to reship packages that they could send to the correct address in the first place? Is it just that you accept a phoney cashier's check or money order made out to you and then you send with your good money? They always want you to do for a month before they pay you so I imagine that is how long they figure it to take to realize you were scammed!
I just have always wondered is it what they are shipping (drugs, et al) that they want "laundered" through your address or the real money from your bank account exchanged for their phoney-baloney money orders???
Back on topic. his pedal pulsing will absolutely go away if he disconnects the module. No doubt about it only happening when ABS system "thinks" it is healthy and on. He needs to answer my question about who told him which sensor was bad and with what device did they reach this conclusion? I would almost bet the farm that test said say RR was bad and changing it made a difference, but it is RR channel of module. Need to know how long he has owned, etc. He has not given me the meat I need to help him or decide re-build vs. new. Know nothing about the availablility of quality indies.
Old 12-03-2012, 02:13 AM
I had driven the car for at least 6 months after i repaired the sensor cable, and everything worked perfectly. The first sight of the problem was on my way from the Alignment Bay. We confirmed the faulty sensor visually by a physical examination. Changed it (although with a wrong unit as I later found out ) the brakes work fine once i disconnect the speed sensor, and the same occurs when i disconnect the ABS module. My mechanic at the time did not use any error reset tool, but I have a Wednesday appointment to check the fault and possibly reset this ...I hope this helps
Old 12-03-2012, 09:16 AM
540iman's Avatar
resident, old fart
YES! If you want me to help you then I will, but I need certain very distinct and chronological answers to rule out stuff. The devil is definitely in the details on these deals.
So, let me see if I have this right as something still does not add up. 6 mos. ago you found a short on one speed sensor. I assume you were lead to this discovery by the trifecta of lights coming on which made you start investigating? Good find on shorted cable which you then repaired and it worked perfect for next 6 months. Sometimes you need not "clear" an error as it will clear itself after couple re-starts or sometimes right away when things are made right. Steer angle sensor re-calibrate not likely to clear itself by virtue of what it reads.
6 months later you get your car aligned and error all of a sudden and totally coincidentally comes back on after alignment and you confirn the repair you did 6 months ago is now no good again? What happened to your first repair? Electrical tape come loose? It was the same sensor you and the alignment shop saw with your eyes was definitely bad, but only after alignment and repair you had made 6 mos. ago was still *fine* when you pulled into alignment shop, but now bad after alignment? Did alignment shop mess with it? (your repair)? Was it same sensor as one you worked on before? What made it unable to be repaired again as it was once before? You have a wrong sensor on there now? What makes it wrong? belongs on front? What did you and the alignment shop see when you both decided it was bad? Did they offer a guess why it was fine when you pulled it and bad when you pulled out? Is cable cut, worn all the insulation off, what is it that makes it bad this time and is it same sensor? You may be able to repair the "old" sensor" again and your error will clear. Did you ever say you had a steer angle error or did I offer that as a possibility? Was alignment way off or what made you feel you needed alignment?
Lots of questions- all are important to me. Please re-read several times and verify you have given me everything you can. Guys here can likely send you INPA diagnosis software and stuff they have "cracked" that will rival the GT-1. I am just not that computer savvy to play with the unknown. I know where my limits are and try not to cross, but there are guys on this forum who are absolute masters at understanding this stuff who may be inclined to help you and your mechanics there. Warning that some software may take some IT knowloedge on your part. Not sure how plug & play it is.
Bill
Old 12-05-2012, 07:54 AM
ABS and traction control lights
Thanks guys for your assist, I finally got some guy with the auto boss diagnosis to check the system and the verdict is that the Abs Module is faulty. There was an error code 5 displayed indicative that the fault was from the rear right speed sensor, but during the test all the sensor reads on the auto boss system when the car is moved. The clearing of this fault did not stop the pulsing and the traction lights come alight once the speedo hits 45 km/h. My only worry is if the Autoboss can code the new module once the unit that I have ordered arrives.
Old 12-05-2012, 08:48 AM
What typically happens is the 7th aluminum wire in the top left of the opened ABS control module has lifted off its gold bondpad (as explained by Bill in his ABS control module autopsy).
Here are all known options - you might have other options in Nigeria that we don't know about though:
- What are all known options when your ABS control module is bad (1)
