Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 11-28-2012, 03:09 PM
mzambrana78 mzambrana78 is offline
Mein Auto: 1985 325e
Replacement rims for e30
I have an 85 e30 and the stock rims are 14's. look like little bike rims. What size can I upgrade to without replacing shocks and springs?
Old 11-28-2012, 06:32 PM
downhiller's Avatar
livin large
16s. anything bigger looks wrong. but you have to get the correct spacing and tire.
Old 11-28-2012, 06:42 PM
Thats what I was thinking about. What size tire do u recommend?
Old 11-28-2012, 08:23 PM
downhiller's Avatar
livin large
225/45 if i remember correctly. i have been wrong before
Old 11-28-2012, 08:39 PM
Krumchev2's Avatar
Krumchev2 Krumchev2 is offline
Straight Bimmin
Mein Auto: 91' 318ic
Don't put 16" wheels on stock suspension. It will increase your wheel gap and just look silly IMO
Old 11-28-2012, 08:50 PM
TrippinBimmer's Avatar
TrippinBimmer TrippinBimmer is offline
Send a message via AIM to TrippinBimmer Send a message via Yahoo to TrippinBimmer
Mein Auto: ZHP Custom Stage 3.5
16x8 Et 5 and 3 here
Old 11-28-2012, 09:52 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
24's over here
as said above, change the suspension before you buy wheels.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 11-29-2012, 05:34 PM
I just put a new suspension a year ago so maybe i will just out 15's. these 14's just look so tiny and small. Have plenty of room for a bit larger
Old 11-29-2012, 05:43 PM
fcsteve's Avatar
610EUROs
what kind of "new" suspension ?
Old 11-29-2012, 06:30 PM
Nothing fancy just the stock brand from autohauaz.com
Old 11-29-2012, 06:39 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
If the tire is sized to match the circumfrence of an OEM tire, the gap won't change at all.
Sent from my MB860 using Bimmer App
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 12-01-2012, 07:22 AM
BigBoy740il BigBoy740il is offline
Mein Auto: 1991 E30; 2000 E38
In reality, the wheel gap does not increase. Your perception in relation to tire sidewall height and fender gap makes it seem larger. I'm running 17s with offsets 20 and15 without any issues. I also dropped the car 40mm to eliminate wheel gap.
Big Boyz with Bad Toyz.
Old 12-01-2012, 08:33 AM
D'oh, You kids!
I think I just said that.
Quotes to live by:
BMW-CCA #441426
Old 12-01-2012, 08:38 AM
Dumb question: what do u mean by 20 and 15 offsets? What is the exact measurements of the 17's u have.
Old 12-01-2012, 05:37 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
google for a picture, its a bit hard to explain
It is the space between the hub and centerline of the wheel. an offset of +45 means that the hub mounting face is 45mm towards the outside of the wheel from the centerline of the wheel itself, and 0 offset means the hub mount face is exactly in the middle of the wheel
Old 12-01-2012, 07:57 PM
I'm running 17x7.5 rims. The 15mm rear wheel offset allowed me to bring the wheels closer the fender well. This gives the rear a fuller, tucked look.
