E30 (1982 - 1993)
Coolant temperature
Noticed my coolant temperature gauge doesn't work on my new 325e. Is there an 'idiot' light that will turn on if it overheats, or will I be completely oblivious if it does? It runs excellently, but that's not the best indicator of engine temperature.
Is there a way to test the gauge before replacing the sensor? I am planning on getting a Bentley but I need to drive around (to work mostly) and I'm not sure where the coolant temperature sensor even is. edit: Oh, and does the fan clutch work off of a different sensor? On my VW it has a separate one so even if the gauge sensor fails it will still turn the fan on. If the sensor is bad and it's the only sensor it's possible the fan will never go on, which obviously is bad. Thanks. Last edited by dliff; 11-29-2012 at 03:48 PM. |
I don't know about testing the gauge sensor, on my 87 325e however, the fan operates from two sensors located on the radiator. One for low speed, the other for the high speed fan. You can test them by jumping the terminals together. If the fan comes on, replace the sensor. I hope this helps.
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
Quick test for gauge function - earth (ground) the sensor wire with the ignition on, engine not running. have someone watch the gauge. It should climb RAPIDLY. If it does the gauge and wiring are good. Change sensor. If not gauge or wiring faulty. Don't leave the wire grounded for more than about 5 seconds - just long enough to see the needle get to about 3/4 scale. There is an overheat light in the red end of the dial face - similar to the low fuel light in the fuel dial face.
If we are talking about the same fan, could you explain why my fan turns on in the middle of winter when I'm running my heater ?
If you have it on defrost, it actually cycles the A/C, even though the heat is on, and running the A/C runs the auxiliary fan.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
That makes sense, thank you for the info
Thank you for the replies. I'll test it out soon.
