Car squeaks loudly - Bimmerfest - BMW Forums
Old 11-30-2012, 10:05 AM
kshade40 kshade40 is offline
Mein Auto: 1999 bmw 323i
Car squeaks loudly
There is squeak near the front if the car..what could it be? a belt!?!
Old 11-30-2012, 10:11 AM
scarede46er scarede46er is offline
Mein Auto: 2001 BMW 325i ZSP
If it is doing it with the engine running and the car not moving it is most likely a pulley or idler. If you havent changed them in the last 50,000 miles, I would replace them all as well as new belts. Cheap insurance against catastrophic damage.
Old 11-30-2012, 10:14 AM
new_kid new_kid is offline
Quietly Learning E46
Mein Auto: 2000 BMW 323i
....or make use of the "Search Button"...to help where to start looking.
Can be one or more of several reasons..
Good luck!
Old 11-30-2012, 01:53 PM
Is it bad if it is not replaced right away?
Old 11-30-2012, 05:11 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
A failing tensioner or idler pulley will chirp a little on cold starts to warn you. Probably could go for weeks on it. A continuous LOUD squeak is either a pulley that will fail soon, or a worn/stretched belt that's slipping and needs replacement or has become contaminated with a fluid and is slipping. You could also have an accessory that's binding (water pump, AC, power steering pump) and causing belt to slip.
The risk is if a pulley locks up and you throw/shred the belt, it can do damage slapping around in there (destroy cooling fan, coolant expansion tank, etc.) and when you lose the belt, the water pump stops and the engine overheats. You don't want that.
Old 11-30-2012, 05:38 PM
^this
