X5 E53 (1999 - 2006)
The X5 SAV Forum |
2001 x5 4.4 starts then dies.....HELP!!!!
my 2001 x5 4.4 will start then dies everytime, throwing these codes:
P0120 = Throttle/Pedal Position Sensor/Switch 'A' Circuit P0123 =Throttle/Pedal Position Sensor/Switch 'A' Circuit High P0223 = Throttle/Pedal Position Sensor/Switch 'B' Circuit High my scantool will not erease them nor will sitting w/ battery unplugged overnight. I replaced the petal assembly and throttle body with new equipment, HELP!!! blakeyatwork@yahoo.com 919-417-4448 someone please text me or email me! |
do I need to recalibrate or rellearn the throttle system, seems like it? process?
P0120 Throttle/Pedal Position Sensor/Switch A Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input |
2001 x5 still starts then stops!
10 days later same issue.
start up and then shuts off after 1-2 seconds Codes: P0120 P0123 P0223 P0103 relplaced ecu from ecudoctors and synced ews new throttle body new gas pedal HELP!!!!!!!!!!!!!!!! |
....help!
...me!
Hey guys Im still down . I know a guy with DIS (bmw software) but he wasnt sure if there was a step in the software that Im missing that makes the pedal talk to the throttle. Right now I have the ecudoctors DME, perfect wires and harneses from pedal to DME, DME to throttle body and a new pedal and throttle. Still showing to high of voltage to throttle codes.
Does DIS have a step in it Im missing. I get the initial open/shut on turn of key of the throttle body but no 10 or 30 second initialization process w/ the key seems to do anything. |
WELL its fixed, cost me 2600$ to figure it out but to save aeveryone trouble, replace the computer (DME) first then if that doesnt fix it its the MAF as well. That combination worked for me. If you do that itll only cost you 1000$
