2003 Z4 E84, temp guage shoots to far right over-hot for a second then retrurns to normal. Engine check light is on as well. Heater only blows hot air intermittently but usually just cold even though temp setting in the cab is all the way hot. I figured it was time to replace the thermostat but have not yet done this on my Z4. Need your help, pics, videos, etc.
Couple of immediate thoughts
1. check your coolant level now 2. sounds like air in the system |
Hi Zeeboy, thanks for posting.
Coolant level good. Not familiar with issues of air in lines? Please explain. |
A quick search will give you a lot of info, here are a couple links about bleeding air to get you started.
http://www.bimmerfest.com/forums/sho...air+in+coolant http://www.bimmerfest.com/forums/sho...air+in+coolant
Pete82 |
These cars have a fail safe thermastate. Once the thermastate reaches a certain amount of high psi it is forced open. This explains the engine overheating and then cooling down a bit. I would replace the thermastate, water pump, and exansion tank at the same time as these typically all fail at the same time.
