Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 12-03-2012, 06:29 AM
mgulizia mgulizia is offline
Mein Auto: 2007 525XI
false oil level readings.
I recently purchased a 2007 525XI. Had everything checked out before purchase. I noticed after around 800 miles my oil light came on. I checked it through the system and it said add a quart. I waited until the end of the day and it said oil level full. I am getting different readings day to day. Any suggestions? Thanks..
Old 12-03-2012, 08:54 AM
pcy pcy is offline
Oil level sensor (attached on the bottom of oil pan) may be the culprit for those erroneous readings.
Replacing the oil level sensor is not that difficult; do it when you are ready to do oil change.
If you are in Nashua, I am not too far from you... Westford
Old 12-03-2012, 09:28 AM
Thanks very much. That's pretty much what I thought it would be.
