Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 12-03-2012, 05:07 PM
Bimmerkid325i Bimmerkid325i is offline
Mein Auto: 1991 BMW 325i E30
Water inside car in front foot wells.
So I noticed today after about 4 days of heavy rain that my footwells in the front, both drivers and passenger side, are wet. The drivers side is worse then the passenger. Also water has been leaking into the trunk. I checked the drains in the sun roof, front, and saw that water drained out under the right right away so am assuming they are not clogged. I checked the drains under the passenger vent outside under the front windshield and wipers. It seemed to drain alright, both the elephant vent in the engine bay as well as the drain under the car. Is there a drain under the drivers side vent where the drivers wiper attaches? If so that seemed clogged because no water came out when checked.
Water was found in the battery box in the trunk. I haven't checked the rear sun roof drains, was going to try and snake them from the rear if clogged.
So suggestions? Also condensation inside cab and trunk today. Thanks
Old 12-03-2012, 06:41 PM
downhiller's Avatar
livin large
well with the weather youve been having, i wouldnt be surprised the the drain were overwhelmed. and the easiest way to get the moisture out, drive around with the ac on. another way, 10gal wet/dry shop vac
Old 12-04-2012, 08:14 AM
james.e30 james.e30 is offline
Mein Auto: 2003 X5 3.0i
Tail light gaskets
Check the tail light gasket that sits between the lens and the bulb holder assembly for the water in your trunk. I had to replace both in my old 318.
Old 12-04-2012, 08:59 AM
BMWFatherFigure's Avatar
Old School
Be careful unblocking the sun roof drains. You could knock the tubes off, good idea to clean them out though. If you want to check for boot leaks have one inside the closed boot and one outside with a hose and start from the lower surfaces and work your way up. Take all the affected trim out and dry it fully - it will promote rust if left damp. I had to do my lamp gaskets too.
Current:
Previous:
Old 12-05-2012, 03:29 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
This is what my dad did on gravel roads to test for dust ingressing into the boot, by having his little son (me) lie in the boot with a torch, whilst he played Walter Röhrl.
Now it is funny
Don't take life too seriously; no one gets out alive !
Old 12-05-2012, 06:57 AM
Old School
but he loved you......
Current:
Previous:
Old 12-05-2012, 07:05 AM
jertronic jertronic is offline
jertronic
Mein Auto: 2008 328 xi sedan
Check the condition of door and trunk rubber seals. A rubber seal surrounds the outline of each door. If the rubber is hard, cracked or missing water and wind/air will enter.
Many 'Fest members use a product to treat and protect the rubber keeping the seals soft playable and lush.
Do a search on door or trunk seals.
2008 328xi E90|N51|monaco blue|premium|sports|cold weather|logic 7|ipod|BMW Assist|xenon|sunshade|HD radio
Old 12-05-2012, 07:07 AM
markseven markseven is offline
an audience of One
Mein Auto: BMW M Power
Heater core? Maybe too much of a coincidence in light of the heavy rain you mentioned...
