BMW presents the BMW Concept 4 Series Coupe - Bimmerfest - BMW Forums
Old 12-05-2012, 07:44 AM
tim330i's Avatar
tim330i tim330i is online now
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
BMW 4 series coupe
The latest generation of the BMW 3 Series Coupe and Convertible leads the way worldwide in the premium mid-range coupe and convertible market. Indeed few, if any, rivals have made such a defining impact on this segment in terms of design, dynamics and efficiency.
Now, with the unveiling of the BMW Concept 4 Series Coupe, BMW is looking ahead to the fourth generation of its sporty mid-range coupe and reasserting its global leadership credentials in the process.
BMW 4 series coupe rear
The "4" a sign of greater exclusivity and presence
The BMW Concept 4 Series Coupe adds a new dimension to the qualities of the BMW 3 Series Coupe in terms of aesthetics, dynamics and elegance.
The "4" doesn't just mark the start of a new cycle, it represents the zenith of a development curve. BMW has given the new model its own individual character and a standalone design and, in so doing, has turned "4" into segment shorthand for aesthetic and dynamic appeal. The latest addition to a nomenclature that sees BMW building on the fine tradition of its large BMW 6 Series and BMW 8 Series Coupes, the "4" stands for greater sportiness, greater exclusivity and even clearer differentiation from the BMW 3 Series range.
The design: a development curve reaches its zenith
The BMW Concept 4 Series Coupe allows the driver to experience the essence of this new, sporting and elegant generation of car in the lap of contemporary luxury. An array of high-quality details provide an exclusive showcase for the car's perfectly balanced coupe proportions. Inside, the expertise of BMW Individual, skilled hand craftsmanship and carefully selected materials combine to create a supreme interior. The role of BMW Individual in the BMW Concept 4 Series Coupe's development clearly underlines the brand's commitment to challenging itself constantly in pursuit of perfection.
BMW 4 series coupe concept
Lower and wider stance sharpens dynamics before a wheel is turned
The dimensions of the BMW Concept 4 Series Coupe imbue the car with a dynamic presence even when it is standing still. The wheelbase (2,810 mm) is 50 millimeters longer than that of the existing 3 Series Coupe, while 45 mm has been added to the front track (1,545 mm) and 80 mm to the rear track (1,593 mm). At 1,826 mm wide, the BMW Concept 4 Series Coupe is 44 mm broader than its predecessor, its roof line is 16 mm lower (1,362 mm) and it is also longer (4,641 mm) all of which makes for exceptionally dynamic proportions.
Perfection in proportions
A BMW Coupe is surrounded by a halo of fascination, and one glance tells the observer all he needs to know about the driving experience on offer. The elegant lines and athletic surface interplay of the BMW Concept 4 Series Coupe embody the qualities and expertise of BMW design and shine out through its sporting silhouette. The car's proportions also fit the familiar BMW template: its long wheelbase, long sweeping bonnet, set-back passenger compartment and short overhangs propel the BMW Concept 4 Series Coupe forwards even before its engine stirs into life. At the same time, its stretched proportions exude a very athletic elegance the rear wheel arches mark the widest point of the car, emphasizing the point and taut lines and surfaces etch emotion and precision into the body. The Coupe's sophisticated detailing also captures the imagination on closer inspection. Functional elements such as air intakes and vents, door openers and exterior mirrors are given a stylistic lift by classy satin-finish aluminum accents. The exceptional dedication of the designers in achieving the right look for each particular function is evident in every one of these details.
BMW 4 series interior
Precision and sportiness in the front seats
Precise contours and multifaceted surfaces define the striking face of the BMW Concept 4 Series Coupe. The hallmark BMW front-end features, notably the kidney grille and twin circular headlights, have a slim, sporty design and ensure the BMW Concept 4 Series Coupe is immediately recognizable as a BMW. The front-end design displays a clear link with the BMW 3 Series family, but its sporting take on the theme accentuates the dynamic leanings of the BMW Concept 4 Series Coupe.
The new concept car lavishes both front-end design icons with meticulous detail and three-dimensional depth. The kidney grille is closed off in the interests of optimizing aerodynamics and keeping fuel consumption low, and the areas between the elaborately designed, satin-finish grille slats are blanked off by dark surfaces.
The full-LED headlights are a hexagonal, extremely technical-looking take on the customary BMW twin circular design. The dynamically chiseled, slimmer interpretation of this iconic design cue integrates seamlessly into the front end. The design of the headlights adopts the link between the lights and kidney grille familiar from the BMW 3 Series and takes it to the next level, rendering this connection visible in darkness as well. An optical fiber leads out from the inner headlight tube and forms a visual link between the inner headlight and the kidney grille. In so doing, it gives the front end of the Coupe an even broader look.
BMW 4 series LED headlights
The most eye-catching feature of the car's nose beyond the familiar BMW kidney grille and twin circular headlights is the large air intake in the front apron. Its wide opening hints at the extra air required by the powerful engines and guides the eye around to the muscular flared wheel arches. The two vent surrounds on either side of the intake replicate the contours of the hexagonal headlight graphics to lend the front end an even wider and more sporting look. Three strikingly sculptured, satin-finish aluminum trim elements in the intake provide added presence. Eye-catching and extremely width-accentuating, they give the aperture a sporty three-way split. The sides of the two flanking vents are of differing thickness and lend the front end a particularly dynamic appearance. At the same time, they mark off specific areas of the intake for brake and oil cooling and for the Air Curtain. This EfficientDynamics feature channels the incoming air around the outside of the wheels, ensuring the airflow "hugs" the wheel arches and fuel consumption is noticeably reduced as a consequence.
A side order of power and elegance
Flowing, typically BMW proportions and a stretched silhouette define the athletically elegant side view of the BMW Concept 4 Series Coupe, with elongated lines and expressively contoured surfaces providing a lively interplay of light and shadow. The gently downward-sloping roofline a classic coupe feature creates a smooth transition into the rear, stretches the overall appearance of the car and takes the elegant route to accentuating the sporting appeal of the car's flanks. The side windows also adhere to the slim and stretched theme. The striking exterior mirrors extend organically out of the shoulder line and provide another example of the eye for detail which allows aerodynamic function to be integrated neatly and with emotional appeal into the car's form. The BMW Concept 4 Series Coupe boasts elegantly molded shoulders, and surfaces and volumes blend harmoniously as the roof slopes down into the rear. The result is a sporty C-pillar design, which merges flawlessly into the sleek silhouette.
2014 BMW 4 series coupe
Below the side windows, the "double swage line" familiar from the BMW 3 Series range lends the car a dynamic sense of forward motion. The shadowed surface above the rear wheel shrinks significantly below the swage line. This accentuates the muscular contours around the rear wheels, emphasizing the car's dynamic flair and hallmark BMW rear-wheel drive.
The Air Breather, an aerodynamically effective aperture behind the front wheels, offers another pointer to the sophisticated aerodynamics of the BMW Concept 4 Series Coupe. It draws a dynamic path between the two light surfaces of the car's flanks, replicating the prominent form of the stylistic front-end elements. The Air Breather brings together the priorities of BMW EfficientDynamics and time-honored BMW design, and works in tandem with the Air Curtain in the front apron to ensure an effective reduction in drag around the wheels. Exclusive 20-inch light-alloy wheels add the finishing touches to the car's dynamically elegant silhouette. Their sophisticated, prominently three-dimensional multi-spoke design underscores their air of sporting elegance.
Broad, sporty stance at the rear
The sporting character of the BMW Concept 4 Series Coupe continues in the low-slung design of the rear. The prominent horizontal lines and stretched tail lights positioned at the outer edges of the rear draw extra attention to the muscular wheel arches and wide track. The design of the rear window has a lowering effect on the car's tail and gives the body as a whole an even more powerful look. It also shows off the car's broad shoulders with satisfying clarity. The horizontal lines of the rear end frame a subtle three-dimensionality, while a tightly structured concave indent in the rear creates shadowed surfaces and gives the car a forward-surging energy. This contrasting interplay of light and shadow brings extra vivacity to the rear end.
The L-shaped rear lights of the BMW Concept 4 Series Coupe blend harmoniously into the car's overall design. They continue the path of the swage line to the side and are absorbed as an integral part of the exterior design. The tail lights taper in towards the center of the rear end, but flare out powerfully towards the outer edges, underlining the Coupe's broad, squat stance on the road. The inner elements of the rear lights recall a sculpture of contorted surfaces. A full-sized light element here reproduces the signature BMW "double L" in three-dimensional form and with impressive depth. While the emitting surfaces shine brightly, those at the back are rather darker, rendering the strong sense of three-dimensionality visible when the lights are hot as well.
BMW 4 series rear led lights
The most striking element of the rear end is the bumper, in which a clearly defined trim element in satin-finish aluminum provides a classy lower edge as the car drops down towards the road. The trim element adopts a similar three-way split to the front air intake, but in a width-emphasizing form. It picks up the two exhaust tailpipes in a dynamic sweep at the outer edges of the rear apron before diverting the gaze to the wheels. Small upturns next to the tailpipes lend additional dynamic flair and finesse.
Interior bathed in subtle beauty
The interior of the BMW Concept 4 Series Coupe follows the traditional BMW recipe, blending sportiness and exclusivity stylishly into a single package. The interior wraps around the driver in typically BMW, driver-focused style. The most important controls for driving the car are grouped ergonomically around the driver to ensure all functions are within the easiest possible reach. The "layering" approach whereby volumes are arranged into layers through the clever use of lines and surfaces underlines the dynamic feeling inside the BMW Concept 4 Series Coupe.
This dynamic use of lines continues into the door design. All the lines streak backwards towards the rear of the car, thus pulling the focus of the interior clearly towards the front. At the same time, clearly defined surfaces around the window sills and door trim panels converge via the B-pillar into the rear in a tightly structured horizontal movement and connect the front and rear compartments. The arrangement of volumes around the doors, side walls and window sills forms a kind of cocoon around the passengers and generates a sporty and secure sense of space. Added to which, the strong contouring of the rear seats makes them appear like two individual seats joined together, emphasizing once again the sporting instincts of the BMW Concept 4 Series Coupe.
BMW 4 series mirrors
Craftsmanship, sustainability and technical refinement
Developed by BMW Individual, the color and materials design of the BMW Concept 4 Series Coupe is tailored precisely to the geometry of the interior. The two-tone Black and Schiaparelli Brown trim provides a particularly effective showcase for the interplay of forms in the front cabin, and light contrast stitching adds a fresh touch to the leather-covered surfaces. This exclusive trim consists of sustainably tanned leather, which makes a convincing case for itself with its natural feel and soft texture, as well as the environment-friendly tanning process used to produce it.
The fine detailing of the BMW Concept 4 Series Coupe exterior is continued inside the car, numerous elements of which reflect the exceptional attention to detail with which the BMW Concept 4 Series Coupe has been put together. As well as discreetly embossed "BMW Individual" lettering on the seats and door sill strips, the seats are also home to very special hand-braided leather trim elements, which run vertically down the seats and enhance the interior's feeling of class. The likewise leather-covered cup holders also adopt the braiding theme, as do the floor mats.
A Natural Chestnut fine wood trim strip adds the finishing touch to the exclusive interior. The combination of carefully selected, high-grade materials, sophisticated details and the extensive use of hand craftsmanship fills the BMW Concept 4 Series Coupe with an ambiance defined by contemporary luxury. The Liquid Metal Silver exterior color developed exclusively for the concept car shows off its expressive exterior design to excellent effect and injects an extra dose of energy into the interplay of contours and surfaces.
Latest Updates on BMW F32 4 series
More about BMW presents the BMW Concept 4 Series Coupe
BMW-Concept-4-Series-Coupe 1BMW-Concept-4-Series-Coupe 2BMW-Concept-4-Series-Coupe 3BMW-Concept-4-Series-Coupe 4BMW-Concept-4-Series-Coupe 5BMW-Concept-4-Series-Coupe 6BMW-Concept-4-Series-Coupe 7BMW-Concept-4-Series-Coupe 8BMW-Concept-4-Series-Coupe 9BMW-Concept-4-Series-Coupe 10
Old 12-05-2012, 07:51 AM
beden1's Avatar
beden1 beden1 is offline
Mein Auto: '11 E93 335is & '08 535xi
It looks sexy in that picture. I'd love to see more pictures.
Current Stablemates:
'12 Porsche 911 GTS Cabriolet (MT); '11 BMW E93 335is (DCT); '08 BMW E60 535xi
Favorite Cars Gone But Not Forgotten:
'09 Corvette ZO6; '04 MB S600; '01 BMW 740iL; '01 Corvette; '90 Nissan 300ZX 2+2; '89 Jeep Grand Wagoneer; '79 BMW 320i; '79 MB 300D; '71 Pontiac Firebird Formula 400; '67 MG Midget
Old 12-05-2012, 08:03 AM
3ismagic#'s Avatar
3ismagic# 3ismagic# is offline
HerrDoktorProfessor
Mein Auto: '11 335d
From the side it looks great. Having said that, the front and rear lower fascia are fugly IMHO. I'm not feeling the interior at all.
To me it looks like they are just trying to find ways to jack the price up relative to the F30.
Entertaining America Since 1975
European Delivery July 26th 2011
ED Video:
ED Trip Report:http://www.bimmerfest.com/forums/sho...d.php?t=557294
335d| Deep Sea Blue| Black/Aluminum | Stuff | Gadgets | More Stuff | Power Whatnots | Auto-Verbing Nouns
BMWCCA #448878
Old 12-05-2012, 08:17 AM
chris328's Avatar
chris328 chris328 is offline
unbekannt
Mein Auto: 750Li Hi-Sec, '13 Actros
i hate that bulbous hood....
Old 12-05-2012, 08:19 AM
Alpine300ZHP Alpine300ZHP is offline
East Coast Commuter
Mein Auto: M4/X6
I LOVE it. If the M4 coupe looks as good as I expect that very well may be my next ride. The prior pics did not do this car justice. This thing looks great.
chris328's Avatar
unbekannt
also if you look at the rocker panels this is not the same f32 that was posted previously being loaded onto the truck. this looks like the m-sport or maybe even the m4.
Old 12-05-2012, 11:33 AM
SamS's Avatar
SamS SamS is offline
Mein Auto: 2013 ActiveHybrid 3
It's neither. The Concept versions always have those extreme lower front/rear bumpers, mirrors and wheels that never make it to any production car.
Old 12-05-2012, 12:21 PM
tim330i's Avatar
That is not always true. The E92 M3 concept was almost exactly what we got for production -
http://www.bimmerfest.com/forums/sho...d.php?t=193190
Tim
Old 12-05-2012, 12:28 PM
SamS's Avatar
Tim
The difference is that the M3 and M5 Concepts were modifications to the regular "series" cars, and less extreme. When BMW introduces a completely "new" line, the Concept version always gets the crazy bumpers, wheels and different wing mirrors. Check out the 6er Concept and 6 Gran Coupe concept. Both of those (like this 4 series) are completely 'new' cars for BMW.
Old 12-05-2012, 12:50 PM
tim330i's Avatar
Good call. There is a lot of similarities between the F32 4 series concept coupe and the 6 series concept coupe.
Old 12-05-2012, 12:25 PM
sr5959 sr5959 is offline
Mein Auto: 428GC M-Sport
I like the headlamp LED design.
Old 12-05-2012, 09:07 PM
pruettfan pruettfan is offline
Mein Auto: 2006 330i
I like it
Overall I think it looks great. I suspect the interior will get toned down when it goes from concept to the actual car. I like that they made it pretty substantially different in terms of styling so we have more choices. I am looking forward to seeing the grancoupe 4 door if it really comes about
Old 12-06-2012, 04:19 AM
boltjaM3s boltjaM3s is offline
Banned
Mein Auto: BMW M428i
Great looking car. Wow.
BJ
Old 12-06-2012, 07:08 PM
mynycbimmer mynycbimmer is offline
Mein Auto: 2013 BMW 328i M-Sport
Looks amazing, if the production car is anything like that it'll be a lot more than a $5K bump over the F30 I would imagine.
The "exposed" F32 in the thread below looks so bland in comparison.
http://www.bimmerfest.com/forums/sho...d.php?t=657959
Old 12-05-2012, 02:04 PM
hans007 hans007 is offline
Mein Auto: 2013 328i m-sport EB2
this is a concept.
i doubt the door handles, / front and rear exhaust will look exactly like the concept.
Old 12-05-2012, 02:08 PM
VIZSLA's Avatar
VIZSLA VIZSLA is offline
Mein Auto: 328 328 308
Originally Posted by hans007 View Post
this is a concept.
The interior will (I hope) be toned down a bit too.
Old 12-05-2012, 03:19 PM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Other than the sea of leather everywhere, the interior is exactly like the current F30.
And that Full Leather trim definitely needs to be offered as an option if this 4-Series wants to really provide a more exclusive "experience" than the 3-Series.
Old 12-05-2012, 03:23 PM
VIZSLA's Avatar
Aren't the A pillars capped in wood?
Old 12-05-2012, 08:21 AM
chrischeung chrischeung is offline
Mein Auto: 2015 550i / 2016 MB C300
NOW they call it a 4 series. I lost a good steak dinner bet to a couple saying that the coupe would be renamed the 4 series when BMW went from Z3 to Z4.
2015 550i ED - M-Sport, Exec, Heated Seats, Rear Shades - 4/9/15
2016 Benz C300
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
Old 12-05-2012, 08:24 AM
BMW meets Audi A5. Nice kid.
2016 Benz C300
Old 12-05-2012, 08:47 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
Rear and sides OK, but man, that front is ugly!
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
Old 12-05-2012, 08:51 AM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: Mini Clubmn,Odyssey,Miata
Looks good the side gills look like an STis.
Old 12-05-2012, 08:52 AM
justinnum1's Avatar
justinnum1 justinnum1 is offline
Mein Auto: F30 335i mSport
that looks like a concept car.
F30 328i Alpine White/coral red Msport 6MT, HK, Xenons, Msport brakes, black grills and side sills, performance exhaust
Old 12-05-2012, 09:03 AM
tturedraider's Avatar
Freedom isn't free!!
Yeppers. Production will be toned down some. Pretty impressive what Individual can do to the interior of a 3er, huh?
BMW must have big plans for the 1er & 2er to take much more prominent roles in the U.S. lineup filling the void left by the past smaller and less expensive 3ers, 'cause I have a feeling this new 4er is going to push most all entry level BMW coupe buyers out of its market and BMW can't afford not to have a strong offering for younger, less affluent new customers.
www.bmwcca.org
Old 12-05-2012, 09:08 AM
KingpenM3 KingpenM3 is offline
Mein Auto: 2013 535i
So are they even planning on making a new 3 series coupe, or a 4 series sedan for that matter? Am I reading it correctly that there will be 3 series sedans and 4 series coupe/convertibles?
2016 BMW M3 ED-11/30/15 PCD- 1/21/16
2013 BMW 535i ED-11/23/12 Redelivery- 1/12/13
1978 BMW 320i (paused project)
2009 BMW Z4sdrive35i (ret.)
1995 BMW M3 (ret.)
1987 BMW 325i (ret.)
4 series concept, bmw, bmw 4 series, bmw 4 series coupe, bmw f32, bmw news, f30 coupe, f30post, f32 coupe, f32post
