Old 12-06-2012, 09:58 AM
pigrad pigrad is offline
Ray
Mein Auto: bmw 320d
clutch
Hi all, I am having a problem engaging first gear. on my e90 320d 2006. It takes a bit of effort to get it in, but if i put it into second and push it into first it goes straight it. any ideas what the cause would be or anyone had similar problems.
Old 12-06-2012, 10:48 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
Sounds like a worn synchronizer on first gear in the transmission. How many miles are on the 320?
Old 12-06-2012, 10:57 AM
Ray
Mein Auto: bmw 320d
73000 miles
Old 12-06-2012, 11:23 AM
Is it all of the time or just occasionally? Next time it happens don't pull it into second. Try releasing the clutch pedal and pushing it in again then try going into first again. It if goes in smoothly then it is probably a worn synchro and you will just want to live with it. It would require a transmission rebuild to fix and it isn't really much more than an annoyance.
Old 12-06-2012, 11:30 AM
Ray
Mein Auto: bmw 320d
Thanks.
Old 12-07-2012, 09:35 AM
Tom K.'s Avatar
Tom K. Tom K. is offline
Mein Auto: '07 328iT.'13 Boxster
You might also try changing the transmission fluid. I found that going to RedLine fluid on my E46 at around 70,000 miles greatly improved the shifting and eliminated the "where is 1st" problem when the car was started in near freezing temps.
May not completely solve the problem - but it's cheaper than a new tranny.
Tom
Old 12-07-2012, 09:54 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Tom
Three last things. Is it worse first thing in the morning, and seems to improve after your engine/tranny warm up?
If you are stopped and try to put it into first is it any different than downshifting into first while slowing down?
Do you ever feel a vibration or hear a noise when snicking into first gear?
Oh, a real last thing...The next time it is difficult to get into first, put it back into neutral. Push the clutch pedal down rapidly three times and hold it. Does it now go into first gear 'normally'?
Old 12-07-2012, 12:38 PM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
Are you thinking bad master cylinder and insufficient hydraulic pressure?
BMW CCA Member
Old 12-11-2012, 12:11 PM
Ray
Mein Auto: bmw 320d
Originally Posted by DSX Machina View Post
:thumbs up:
1) it goes in easier when its warm
2) if your moving slowly it goes into first easy
3) there is no vibration, but you hear a noise like a knuckle crack.
I tried pushing the clutch down three times, there is no difference. pigrad
Old 12-13-2012, 09:41 AM
usaret usaret is offline
Mein Auto: A Gamma Goat
I switched from BMW MTF-LT3 to Redline MTL about 80,000 miles ago and mine has exhibited "balky" cold shifting into 1st ever since. But Redline MTL is thicker so it was expected and I'm just gentle with it until it gets warmed up. For me a 5-6 shift seems to line everything up so it will go smoothly into 1st when cold. So to me is sounds like you need an oil change. If it were hydraulic I would think you would have engagement problems in every gear.
I went with the thicker MTL because I live in the SE USA where summer temps are brutal and I wanted a thicker oil in my tranny. With the OE oil I used to get very pronounced gear rattle at idle in neutral with the clutch out. With the MTL it's almost imperceptible even on the hottest days. My tranny oil changes show just a couple of gold specs of synchro material and virtually no steel so I'm very pleased with the results of the Redline MTL.
Old 12-13-2012, 10:30 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
The recommended fluid is redline D6 for manuals
The recommended redline is D6 this is closer in viscosity to the bmw spec and provides
better start up lubrication than a heavy oil. At least that is what I have read and its
what redline says to use in there app. Some were using D4 which is more viscous I believe.
Old 12-13-2012, 01:51 PM
You are exactly right.... D6 is what's recommended but only for ease of shifting at low temperatures. I talked to Redline about this very thing but went with MTL 82,000 miles ago. I've changed it twice since then and I've had zero wear issues. The ZF GS6-37 transmission is splash lubricated so the thicker oil will have no negative effect on "start-up" lubrication.
Name:	ZF GS6-37.jpg
