E36 (1991 - 1999)
Crank fan delete
what is needed to do a crankshaft fan clutch and blade delete?
Google-fu is the only thing you need.
“No cop born isn't a sucker for a finely-executed hispeed Controlled Drift all the way around one of those cloverleaf interchanges. Few people understand the psychology of a traffic cop. A normal speeder will panic and pull over to the side when he sees the big red light and start begging for mercy. This is wrong. Contemptuous to the cop-heart. When running along about a hundred and you find a redflashing CHPtracker on your trail you accelerate.” - Hunter S. Thompson, |
i guess im not understanding.. what do you mean?
Please do not do it. The cooling system in e36's is the weakest part and you are talking about making it weaker.
Alex//1999 323is - power e46 m3 seats, style 43 rims, 328 exhaust For sale black e46 interior parts “Dude, dolphins are intelligent and friendly!” — Wendy “Intelligent and friendly on rye bread, with some mayonaise.” — Cartman |
i have the stage 3 cooling refresh kit from ecs tuning.. would you still recomend not doing it?
I'm saying to use the search function.
Not only will it tell you step by step how to do this (as it has been covered no less than 50 times) but will also tell you as alluded to above, why it is a bad idea.
The funny thing I've never understood about this is......what exactly do you think you're gaining?
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
i want to take the weight off the crankshaft but idk if it would be an ulpgrade or downgrade
/thread.
Not only is that weight negligible in operation, the crank bearings were designed with that load in mind. I don't heat of a lot of crank bearing failures, do you? Sent from my LG Revolution 4G using BimmerApp
No, the pump lost bearings cause either its old/worn. or your fan might be missing a blade or two...
I dont have a clutch fan, but i dont think theres much of a difference
what do you mean you dont have a clutch fan? do you have a direct fan or something?
like theres no fan connected to my waterpump.
did you delete it? what does it look like?
It definitely does not make any practical sense to remove your fan, and is making an already extremely weak cooling system even weaker.
And if your fan clutch bearing has "lost a couple balls", I wouldn't even drive the car like that. If it gives out while the engine is on, it could send the fan flying into the radiator, hood, hoses, etc, thus making a $30 & 15 minute repair much more costly.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
this thread hurts my brain....
STAHP
Look under your hood. Then ignore the fan. And picture thr waterpump with only a threaded nut sticking out lol
Lolz Sent from my SPH-D710 using Bimmer App
Also to the OP (that's you JDMdudewhatever) the clutch fan weighs so little that you will get NO extra power by removing it. The electronic fan is meant to supplement the belt driven one, and not perform the whole duty. Our engines are very susceptible to overheating, and once you do you'll either wreck the head which is bookoo dollars or you'll blow the head gasket which is nearly as expensive to repair if you can't do it yourself. So to save yourself money in the long run, not to mention the brand new radiator you're probably planning to install, replace the damn fan and fan clutch
i searched it for you and took LESS than 5 minutes http://www.pelicanparts.com/cgi-bin/...ch%20%20%20%20 ^fan clutch http://www.pelicanparts.com/cgi-bin/...ch%20%20%20%20 ^fan EDIT: You'll also need a new waterpump if there's a ball bearing missing. http://www.pelicanparts.com/cgi-bin/...0Each%20%20%20
#25
In shorter words, dont remove it, replace the broken stuff. Have piece of mind Sent from my SPH-D710 using Bimmer App
