Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 12-07-2012, 07:23 AM
gwurst gwurst is offline
Mein Auto: 2005 645Ci Convertible
Lightbulb DIY: How to remove the front grills WITHOUT removing the bumper
So I had a grill with some bubbly chrome I wanted to replace. Did some searching and the common response is to remove the bumper. Really didn't want to do that if I could avoid it, so I looked at the replacement grill and noticed it's held-on with 7 clips. If I reached in the grill I could feel and get to all 7 clips, but with your fingers there's no way to get into the center of the clip to depress it.
Then it hit me, the radiator hose removal tool!
I got mine at a Big Lots, but you can get them at most automotive stores or Amazon:
http://www.amazon.com/OTC-4521-Hose-...sim_sbs_auto_1
With a flashlight you can look in the grill to see where the clips are. Starting on the bottom 3 clips insert the tool and get it under the center of the tab:
Then, just angle the tool up and depress the center tab while gently pulling on the grill to remove that tab:
Once the bottom clips are released move to the top. Start with the clip nearest the center of the bumper and continue until you have the grill removed:
Here you can see the old grill at the top and the new grill on the bottom. Old grill had the chrome starting to bubble at the top left:
Now just push the new grill back-in and you're done!
Took all of about 10 minutes to replace. On a related note, if anyone needs a driver-side chrome grill with some slight bubbling let me know.
Old 12-07-2012, 07:26 AM
Here's the IMGUR gallery in case you want to see larger pictures:
http://imgur.com/a/8sfjl#2ZOSS
I've also attached the pictures in case IMGUR deletes them eventually.
ID:	352234   Click image for larger version
ID:	352235   Click image for larger version
ID:	352236   Click image for larger version
ID:	352237   Click image for larger version
ID:	352239   Click image for larger version
Old 12-07-2012, 11:28 AM
greco2000's Avatar
greco2000 greco2000 is offline
Mein Auto: 2008 650i LCI
WOW! Score! Thanks for writing this up!
2012 BMW M6 CONVERTIBLE
Old 12-07-2012, 06:55 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Nice! Great job on figuring that out. I did the grill removal with a standard screwdriver and I can tell you I used every swear word in the book.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 12-07-2012, 06:59 PM
Thanks for the kind words. I've already snagged several good write-ups from here so it's nice to be able to give something back.
Old 12-12-2012, 02:39 PM
bismarck bismarck is offline
Mein Auto: BMW 645ci
I had to wangle mine out with a table knife! Ha. This would've been handy
Old 05-07-2014, 02:26 PM
luvmybeemerbike luvmybeemerbike is offline
BMW bike whore
Mein Auto: 2013 BMW X1
Great write up and cool trick. We have an X1 and getting those grilles out are a real PITA!
Old 05-07-2014, 03:11 PM
This is very cool, I had never seen this before. Good to store in the memory bank...
Old 06-09-2014, 07:45 AM
guyver626 guyver626 is offline
Mein Auto: x3 35i
Ha! I thought I was the only one that used a kitchen tool! Lol. I used a butter knife and I was cursing like crazy.
But in the end I got it done with no damage to the car or grills. Just scratched up hands and arm lol.
Old 05-07-2014, 02:24 PM
BMW bike whore
Very cool write up and trick! Now to find that tool.
Old 05-28-2014, 09:52 PM
R2F06 R2F06 is offline
Mein Auto: 640i GC
Good idea. Thanks for the tip.
Old 06-08-2014, 01:00 PM
BMW bike whore
Well an hour and a sweaty half later, old grilles still in place. This is a real chore and honestly, a HUGE pain in the rear. I thought using the tool would be so easy but for whatever the reason the tool just isn't allowing the tabs to release. Some in the X1 forum have said I have to release the 4 screws at the top and the head light washer covers but honestly, I couldn't even begin to get my hand in from the top! What else can one do or try to get these freaking grilles out?
Old 06-08-2014, 08:20 PM
roseng's Avatar
roseng roseng is offline
You can rmove the entire bumper. It's actually a fast to do but I have also been able to get the grills off with the tool. It does take some patientice. I don't think you cannot do it by lootening the screws
Old 06-09-2014, 03:19 AM
BMW bike whore
If I had no choice but to remove the bumper I would, but body shops and the like don't remove them, they couldnt, it would be to time consuming. True, I don't want to damage my bumper and I do have the time but I just can't see pulling the bumper cover and the headlight washers to do this job! It's frustrating to say the least.
Old 06-09-2014, 07:27 AM
Yorgi's Avatar
The key for me was to pull out on the grill (towards the front of the car) keeping constant pressure while pressing the tabs. The tabs will then pop once you release them and stay released. I also found it easier to work on the top row first starting on the outside tab, not the bottom-row/middle tab as suggested in the DIY.
Removing the bumper takes about 20 minutes and is a two person job so if you are spending hours trying to get the grills out you should just bite the bullet and pull the bumper. If you have not already seen it, there is a good DIY here for the bumper removal.
'04 M3 - track
Old 06-09-2014, 07:50 AM
Mein Auto: x3 35i
I'm sure you don't want to do this but I came close to almost breaking or cutting off one of the grill fins so I can get my hand in there. But they did bend enough where I was able to get my arm in and release the tabs. It did cut up my arm alittle but way better then removing the bumper. In the end I didn't break or damage anything.
Old 06-09-2014, 10:49 AM
BMW bike whore
I almost cut the slats yesterday now that you mention this. But in the end, I want to keep the original grilles for just in case. Removing these grilles from my model (X1) seems to be more of a pain in the rear than most other models. I first tried removing the four torx bolts on top and I couldn't get my chubby little arms in and behind the grilles no way, no how. I'll keep trying once the weather breaks again. Thanks to everyone who has tried to help, I appreciate it!
Old 06-09-2014, 11:10 AM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2014 BMW ///M6 vert
Not sure if there is a difference across grills for different model BMW's but thought I would point out that this is a DIY sub-forum for six-series BMW's (645, 650i, etc.). All of the advice on this thread pertains to the six-series, so not sure if is exactly applicable to your X1.
Regards, Greg
'14 M6 vert, san marino blue on amaro brown full merino leather, drivers' assistance, exec package, B&O sound system, CCB package, akra exhaust, tint, windscreen, etc.
'07 650i vert, beige/jet black, sports & cold weather pkgs, comfort access, etc.
'11 Acura MDX Advance with Entertainment pkg for wife - no mod's '04 Acura TSX (daughter) and '12 VW GTI - Autobahn (son)
Old 06-09-2014, 12:15 PM
BMW bike whore
@ greb, yes I am aware of this being a 6 series forum, was kind if hoping that these grilles were a universal type of thing. Unfortunately, I'm thinking this isn't a universal thing.
Old 06-09-2014, 12:53 PM
gregb's Avatar
yep... leave it to the German engineers to come up with different systems to attach the same things while thumbing their noses at commonality...
Regards, Greg
Old 06-09-2014, 01:39 PM
BMW bike whore
Yep, nothing is ever so easy when it comes to something so recognizable such as the BMW kidney grilles!
Old 08-20-2014, 08:20 PM
rawdog805 rawdog805 is offline
Mein Auto: 05 645Ci
These instructions are great. I went and bought the tool for $3 from harbor freight, and 10 minutes later the grill was out and the new black one was in.
Thanks.
2005 645 Ci (Sold)
8000K HID Bulbs + 7W Ebay Halos & Fog Lights + 21" 128 Style Wheels + K&N Air Filter + Replica CSR Front Lip + Triple Resonator Delete with X-Pipe + Aux Input with Bluetooth Dongle +
2002 745 LI (Sold)
2006 X5 (Sold)
Old 08-21-2014, 02:50 AM
Big Jon Big Jon is offline
Big Jon
Cool
All you guys have to do is remove the upper bolts that hold the bumper cover in place across the top of the radiator housing and you can easily pull back on the bumper cover enough to gain access to the upper grill clips. The lower three clips come out easily with no problems. The top 4 clips you will really need to see and be able to get to. Just remove the top screws and it becomes very easy!
Name:	BMW 645 GT.JPG
Old 08-21-2014, 06:12 AM
Mein Auto: 05 645Ci
Yeah but it's much quicker using this method and easier. No need to worry about stress cracksin the bumper with this method.
2005 645 Ci (Sold)
2002 745 LI (Sold)
2006 X5 (Sold)
Old 01-28-2015, 07:14 PM
Nobrega645 Nobrega645 is offline
Mein Auto: 645ci
If your replacing the grill why not just hack the old grill out with a mini hack saw then you would have better access with any size flathead screwdriver to remove the rest out.....just thinking out loud.
bumper, grill, replacement
