Old 12-07-2012, 05:24 PM
AlSmith1964 AlSmith1964 is offline
Mein Auto: 2002 745i
2002 BMW 745li gives a Fault in Pass-restraint system
So I have the message “2005 BMW 745li gives a Fault in Pass-restraint system” a friend of mine told me to replace the seat belt receiver, so I did. I used INPA and cleared the codes. Well the error came immediately back. I cleared them again and immediately the error came back again. Any suggestions, is it the pressure mat? I would really like to find a solution. Thanks.
Old 12-09-2012, 09:45 AM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
2005 model year has a 10 yr extended warranty on the seat occupancy mat. I had mine replaced recently at no cost. There is a SIB on the topic.
2005 745i Individual
E65/E66 Parts for Sale:
Alpina Type 743 Front Spoiler complete retrofit kit (new in box) $1200
Old 12-09-2012, 10:43 AM
asanti128 asanti128 is offline
Mein Auto: bmw 745 li
Try a new battery and register it. Clear code. Low voltage throws that code. Happened to my 7
Sent from my DROID RAZR using Bimmer App
Old 12-09-2012, 01:04 PM
I have a new battery, the car is a few months over 10 years, but I'll call the dealer it cant hurt. Will DIS tell me what part to replace?
Old 12-12-2012, 09:40 PM
KaileSvick KaileSvick is offline
Mein Auto: 2003 BMW 745Li
Its usually the mat in the seat that goes bad
Old 12-13-2012, 02:30 PM
Ok, I'm convinced it's the mat. Does anyone know how hard it is to replace?
Old 12-13-2012, 05:09 PM
rsbolin@me.com rsbolin@me.com is offline
Mein Auto: 2004 760i
Could be the safety terminal from the battery change. I have heard of that throwing a code.
Old 12-13-2012, 07:14 PM
If im not mistaken, when the safety terminal has the problem it shows up with a drivers airbag fault message instead of the passenger.
Old 12-29-2012, 06:32 PM
I changed the battery, now the alt went out waiting to see what happens after install. Will keep advised. Thanks for the input!
Old 12-29-2012, 03:59 PM
nick2481 nick2481 is offline
Mein Auto: 2002 745li
It could be the control module. I had the same error on my car. 02 745li. After a new control module the software might need updated.
Old 12-30-2012, 08:27 AM
Davidf Davidf is offline
Mein Auto: various BMW's
"Passenger" in this context means all occupants. Not passenger vs driver. So, the fault does not tell which the problem is on. It could b anything and you need to use INPA to find the problem. On my 5, it was the driver side door module. Everyone wanted to blame the seat sensor, but that was not the problem.
Old 12-30-2012, 09:59 AM
los2much's Avatar
los2much los2much is offline
Mein Auto: 745li
if you replace the seat from a salvage yard would it fix the problem
Old 12-30-2012, 04:25 PM
The mat is only $80 I'm going to buy it new after I replace the Alt. The Alt was $269 rebuilt. Thanks for the advice!
