E46 2003 drivers door wil not manually lock or unlock - Bimmerfest - BMW Forums
Old 12-08-2012, 05:11 AM
Major2014 Major2014 is offline
Mein Auto: 318i E46
The drivers door on my E46 will not lock or unlock with the key manually inserted. It feels like the key/lock is not connected to anything.
The beeper key works to lock and unlock the car, however on occassion it fails and I have to manually unlock the car.
Does any one know what the problem is with the door lock?
Major 2014
Old 12-08-2012, 07:03 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
There is a physical connection between the lock cylinder and the electronic actuator which is easy to check without removing the door panel. I'd start there...
Here's a great thread on the topic:
http://www.bmwenthusiasts.co.uk/foru...php?f=55&t=941
To remove the key mechanism from the door is quite easy. There is a black rubberized covering inside the door (striker side) that hides an access hole to the retaining screw. This image from a Fanatics thread shows how to access it:
Jeff R.
