Old 12-08-2012, 11:04 AM
colink colink is offline
Mein Auto: 2004 645Ci Convertible
SAE or Powerlet connector
Does anyone know if there is an SAE or Powerlet style connector anywhere on a 6 series that can be used to charge the battery please?
I was thinking of getting a ctek charger and comfort pigtail which connects via an SAE connector. I could also get an SAE to Powerlet adapter.
Old 12-08-2012, 02:37 PM
So no-one has had an answer and my further research indicates that the Powerlet connectors are more common on BMW motorcycles.
So, ctek also sells a comfort indicator with eyelet connections.
Are there any risks associated with unbolting the positive and negative terminals in the engine bay to place the eyelets on them please?
Old 12-08-2012, 08:07 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Way less weekend activity on this board so you would be lucky to get an answer in 3 hours.
Here is a thread with pics of the quick-disconnect connectors you are asking about. CTEK offers them. Most people are adding them in the trunk.
If you do a search you will find a few threads talking about the pros and cons of charging at the battery vs under the hood as recommended by BMW.
I would drill a small hole in the positive charging plate under the red positive terminal cover and use a small bolt to attach the quick connect wire. The negative can be attached anywhere you can find a decent chassis connection.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 12-09-2012, 01:31 PM
Thank you Yorgi! (Wonder how many hits I would get if I searched for those words. :-)
I will search on some other words and read the post you linked.
I like your suggestion.
