Old 12-08-2012, 04:47 PM
blingin96's Avatar
blingin96 blingin96 is offline
Mein Auto: e39 540i , E36 328i
540i e39 dual exhaust conversion (my conversion)
Hello all, I have been thinking of doing it but the thinking has got the best of me.
Last month I did the front and rear M5 bumpers with some other bells and whistles. When I got to the rear bumper having only one exhaust outlet was KILLING me. So much that I never installed the rear diffuser.
Today I cut the other outlet on the diffuser then got carried away. I took out the tape measure and started cutting a piece of sheet metal. I AM going to keep the full size spare in place. I did not finish the job BUT the sheetmetal is cut and ready to be welded in. The fabrication took a few hours but I think it's comin along fine.
Here are some progress Picts.
I plan on starting the welding and cutting the trunk on Monday.
ID:	352390   Click image for larger version
ID:	352392   Click image for larger version
ID:	352393   Click image for larger version
ID:	352394   Click image for larger version
ID:	352396   Click image for larger version
ID:	352397   Click image for larger version
ID:	352398   Click image for larger version
ID:	352399   Click image for larger version
Old 12-08-2012, 04:56 PM
blingin96's Avatar
A couple more Picts.MORE to come.
ID:	352401   Click image for larger version
Old 12-08-2012, 05:03 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
so you did a battery delete? how do you start your car now? jk
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 12-08-2012, 05:53 PM
moots's Avatar
moots moots is offline
Dinggg....what now!
Mein Auto: '04 525i
wow....u are a brave man.i don't think my hands will do what my mind wants to......
as an alternative:
Old 12-09-2012, 05:51 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
as an alternative:
I likey !!!
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 12-08-2012, 08:40 PM
blingin96's Avatar
I still need to find some tips for the system. I'm searching eBay right now. ( I'm up for suggestions for the tips).,Tips get expensive!
I plan on keeping the resonator ( the lung looking piece) and cutting another hole on the opposite side similar to the M5 piece. I am not going to run any mufflers after that point. It just going to be straight out after the resonator.
Right now i have the (resonator) off and only running one of the rear silencers. It really isn't loud at all. So I figure putting the lung back on and two outlets out the back should be ok. This will also minimize the cutting and the size of the hole I will have to make in the trunk.
Old 12-11-2012, 05:06 AM
moots's Avatar
Dinggg....what now!
Mein Auto: '04 525i
oh now i see.....i was wondering how a whole muffler was going to fit in the tiny space that you just cut out! but then again,wouldn't the setup be a"lop sided" and unbalanced ie no muffler on the rh side with just a straight pipe coming out from the "lungs"?
this is interesting....most cut out a 1/4 of the trunk space to accomodate the muffler and sacrificing spare tyre space........
completed pics a must........
Old 12-11-2012, 08:36 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
He did say he would run straight pipes from the "lung."
Old 12-10-2012, 10:23 PM
blingin96's Avatar
The outside red lines is the outline of my template. The inner red line is where I'm going to cut. This way I can fold it to my template to cover any gaps.
Old 12-10-2012, 10:25 PM
blingin96's Avatar
After the cutting.
Old 12-10-2012, 10:38 PM
blingin96's Avatar
I tack welded the template in place. Then hammered up the excess metal from the trunk to cover any gaps as my template was not perfect.
When I hammered up the excess metal it then fit perfectly. I then welded and applied a sealer ( its like automotive caulking) over the welds. This way I KNOW it's sealed and waterproof. I did the same on the inside of the trunk.
Tomorrow I will spray some rubberized undercoating just to make SURE it's all sealed and it will match the OEM undercoating. I could not spray it today as the sealer was not cured.
ID:	352768   Click image for larger version
ID:	352769   Click image for larger version
ID:	352770   Click image for larger version
ID:	352771   Click image for larger version
Old 12-10-2012, 10:42 PM
blingin96's Avatar
Here it is without the undercoating. I test the rear diffuser and it looks great!! More Picts to come.
ID:	352777   Click image for larger version
Old 12-11-2012, 05:12 PM
blingin96's Avatar
I will be cutting another hole on the passenger side of the 'lung' then add some 2 1/2 pipes. Similar to the M5 lung with the two outs. Then to some tips.
Old 12-28-2012, 09:49 PM
blingin96's Avatar
Finally completed this mod 2.5" piping and 2.5" DUAL TIPS!! I cut a hole in the LUNG looking resonator and added dual outs. It looks like a straight through design inside the resonator so I figured it would work. It sounds AWESOME!! No drone in the cab and its not too loud.
The sound is similar to deleting the lung resonator and one of the silencers BUT its a deep throaty sound!! Best part is I didn't have to buy any other mufflers. It REALLY does sound great.
Overall a great mod and project. Just measure twice or three times and start the cutting!!
I definitely have no regrets and would do it again in a heartbeat. I love the way my car looks and sounds!
ID:	355026   Click image for larger version
ID:	355025   Click image for larger version
ID:	355027   Click image for larger version
ID:	355028   Click image for larger version
ID:	355030   Click image for larger version
ID:	355031   Click image for larger version
Old 12-28-2012, 11:38 PM
Silverlight95 Silverlight95 is offline
Mein Auto: 2001 540i sport
Great work with fabricating! Really turned out well. Sounds clips?
Old 12-29-2012, 12:17 AM
emmanouil emmanouil is offline
Mein Auto: E39 530i & E200
Nice work, welcome to the club of Quad Exhaust System
My conversion you can see here
http://www.bimmerfest.com/forums/sho...6&postcount=64
Greeting
Emma
Sorry my english ist not so good
My Homepage
Club-Homepage
For Sale
BMW E39 H&R Mono tube coilover 520-530i Sedan
Old 12-29-2012, 04:03 PM
blingin96's Avatar
I hope this works. Video attached
Old 12-30-2012, 12:09 AM
sorry i dont see the video
Try posting it on youtube then posting the link maybe?
Old 12-30-2012, 12:24 AM
blingin96's Avatar
I hope THIS works!!
Old 12-30-2012, 12:56 AM
I hope THIS works!!
All better
Oh and that exhaust is probably the most aggressive sounding i have yet to hear on a 540. Seriously, how'd ya fit the lion in there?
Old 12-30-2012, 05:07 AM
mpower997's Avatar
mpower997 mpower997 is offline
Mein Auto: '90 325i
I hope THIS works!!
What year and milage are you workin with there?
Old 07-04-2014, 09:52 AM
makenzie71 makenzie71 is offline
Mein Auto: Cars...bikes...and nikes
I hope THIS works!!
I would like to hear this but the video seems to be set to private...
Old 12-30-2012, 05:38 AM
blingin96's Avatar
I have a 97 540i it has 112000k miles
Sent from my SPH-D710 using Bimmer App
Old 12-30-2012, 07:23 AM
mpower997's Avatar
Mein Auto: '90 325i
Any pics of inside the trunk with the battery installed, does it get hot?
Old 12-31-2012, 05:26 PM
blingin96's Avatar
Inside the trunk picts. I just put it all together its the best I can do. The battery does not get hot. I drove it for about 2 hours today then I checked it. It felt like a cold battery.
ID:	355372   Click image for larger version
ID:	355373   Click image for larger version
ID:	355374   Click image for larger version
