E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
LED lighted headliner
Okay so you guys know that my headliner looks like this:
(not the most recent) ![]() At night i can imagine that the headliner having like a moonlight glow. so i want to achive that. Im looking to buy 5 blacklight LED's single bulbs. I have no clue what im looking for here.. and the cheapest i found was 1.99 on amazon each... i though LED's were cheap? f*** Then im looking for a small dimmer switch that i want to install down near the steering wheel.... like below the column but on that lower dash area. so a small black dimmer so i can control the blacklight that is emitting from these. How do i wire these to make them all the same brightness and run off the dimmer? i cant imagine it... I know it would be a pain... but can you draw a picture? im going to try to draw one too... to see if my idea is right. but would i be wiring up in parellel or in series? series will cause them all to spilt power and parrellel wouldnt right? would i need any resistors or anything of the sort? what power line should i be thinking of taping into? and then the ground.... just anywhere on the chassis? does either of these look right? sorry if they are terrible or wrong... im just guessing
nothing.
First one (parallel circuit) and, yes, you need a dropping resistor unless you buy 12 vdc LEDs. Most of them operate on 1.5 volts.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
![]() and what level of resistor should i buy? like its measured in Ohms right?
nothing.
http://www.superbrightleds.com/cat/led-accent-lighting/
ooooops....looked like i dropped something.... ![]() have ordered leds fromthese guys, and iirc they had decent prices. (yet *another* project that is on the backburner.... df
[QUOTE=drivinfaster;7238851]http://www.superbrightleds.com/cat/led-accent-lighting/
ooooops....looked like i dropped something.... ![]() have ordered leds fromthese guys, and iirc they had decent prices. (yet *another* project that is on the backburner.... I want to change my angel eyes on my X5. I want to change them to the new angel eyes. The bright super white. Any idea on what I should be looking for in this site? I don't want to order the wrong one. Sent from my SPH-D710 using Bimmer App
[QUOTE=TouTou;7238915]
Franklyn sounds like a fun project...you need the sunroof motor cover? I may have one.
Part out. http://bimmerfest.com/forums/showthr...67#post7418867 "Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI Stock 2004 X5 3.0i (Wifes) E30 87 325e |
Tee hee. df, you're so subtle, dropping things under your desk like that...
The Evolution of a Lady Quote:
Member of the Non-M Bumper By Choice Club![]() |
na i have one... just wasnt in this photo
nothing.
Go find a wiring diagram for the Rolls Royce Drophead Coupe, it was an option on those to have starry sky effect LED headliners.
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
Good looks I have to look in to that. It would look a lot better if it was super white angel eyes
Surprised no one brought this up, but a dimmer switch does not work the way you would think on LEDs.
LEDs are like switches, either ON or OFF. To properly dim LEDs you need to modulate the voltage very quickly (called Pulse Width Modulation). Rather than try to give you an LED 101 course, just look up some pre-built LED driver that has what you want on it. It won't be as cheap as your LEDs (yes, $2 for Blacklight LEDs are cheap). Cool idea, though.
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
What you write may apply to the Z3 and Compact. A E36/2/4 dimmer unit, however, does use Pulse Width Modulation, but with a linear, ca. 20-100% dimming curve meant for incandescent lamps. To provide uniform and sufficient dimming, a PWM dimmer for LEDs needs a non-linear (exponential or square-law) dimming curve that ranges from nearly 0 to 100%. I couldn't find a suitable automotive LED dimmer when I looked a few years ago, and ended up designing one to dim a pair of 10 mA LEDs in series.
You face the same issue when you change the interior lights to LED. I square the linear, PWM, ramped lighting signal from the ZKE (and change, say, 10% on to 1% on) which seems to do the trick. Last edited by johnf; 12-10-2012 at 09:10 AM. |
If you use a linear control the power NOT delivered to the LED has to be dissipated by the control device. When the LED is fully dimmed the controller dissipates all the power. When you use PWM the only dissipation in the controller is due to the losses in the internal switching circuits. You are actually turning on the LED at full brightness but for a short time and off for a time at a rate fast enough that your eye can't discern the flicker. As you increase the ratio of on to off the LED appears to be brighter and when you decrease the ratio of on to off it appears to be dimmer. Quote:
As a practical example, I have a couple, series-wired, white LEDs in my dome light that illuminate the center console. I pulse width modulate them: with a 100% duty cycle, to light a map or a list of directions, and with a 1% duty cycle to provide ambient lighting. If I am unlucky, one of the LEDs might not even stay lit, if instead, I were to reduce their current from 10 mA to 100 uA – to say nothing of how their hues might change. Quote:
I don't know how good it is, but I found this LED dimmer.
http://www.ebay.com/itm/DC-12V-8A-LE...item4168bc1f32
Could pull it apart and run an external pot if you wanted to.
http://dceuro.com/forum/ |
no i havent.
I stopped replying in this thread because im not going to do it. not worth it to me. wanted it to be like a 10$ budget project.. and its way more than that. so no me gust
nothing.
bottle of glue: $0.99
jar of glitter: $2.99 pocket flashlight: $4.99 picture of teh lowness e36 with dedazzled headliner in a tiara?? priceless!! ![]() c'mon,...you know ya wanna!! ![]() df
you guys are too much.
Indeed. It is a quaint and neglected way of considering things.
