E30 (1982 - 1993)
Old 12-10-2012, 02:28 AM
van31 van31 is offline
Mein Auto: E30 318i 85, E30 323i 84
Taco reading wrong?
Recently bought an 85 323i, but the taco is reading far above what it should. It has the standard gearbox, which in my other 323i does 80km/ph at 2000rpm in 5th.
My new car reads approx 3000rpm.
There is a definite pattern of the rev 'boost' it follows an extra 50% to what it should.
Could this be because the instrument panel has been replaced with a 4 cylinder one? so it is reading 50% more ignitions?
Also, just replaced the timing belt, tensioner, adjusted the valve clearances and gave the dizzy a clean, will i have to re-time the engine?
I want to get the car and everything in it running well, as i just passed my blueslip/ roadworthy inspection today.
Old 12-10-2012, 06:47 AM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
just because they are both 323's doesnt mean they have the same rear diff ratio
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 12-10-2012, 06:53 AM
7pilot 7pilot is offline
Git
Mein Auto: 90 Ford Tempo
If you are certain that the tach is from a 4 cylinder car, then that is probably the reason.
If the entire cluster is from a 4 pot car , then the coding plug will also be the wrong piece.
You'll be looking for a six pot cluster to be certain of the correct revs.
m
Old 12-10-2012, 11:18 AM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
I like taco's.
Old 12-10-2012, 12:58 PM
hornhospital's Avatar
D'oh, You Kids!
Me too. 'Specially shrimp tacos. :yum:
4 cylinder cluster in a 6 cylinder car will read 50% over actual RPM, just like pilot said
Quotes to live by:
Old 12-16-2012, 07:34 AM
On Top
I prefer Latina errrr Mexican.
Old 12-16-2012, 11:22 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
all of this taco business and noones answered the problem
OP, assuming you still have you 323i cluster, on the front of it and also the 4cyl one, you will see a white part. this can come out, and can be swapped over. the cluster itself is actually the same, its this white module that tells it whether the cluster is in a 4cyl or 6cyl car.
E30 above Sold
Last updated 2nd January 2014
Old 12-17-2012, 05:42 PM
On Top
Well, I wouldn't recommend something that doesn't apply to him Andy.
You DO know when the coding plugs were introduced right? His car is an 85 M10 318i chassis.....
Old 12-10-2012, 03:40 PM
WickedFast.Inc WickedFast.Inc is offline
Go Fast or Go Home
Mein Auto: 1989 325I
My taco usually reads ok it read about mid level meat cheese and lettuce
Wicked Fast Entertainment
Old 12-12-2012, 03:24 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
TACH!!! Or Tachometer. None of them are super accurate. Swapped eta to 7k Tach in my e30 before the M52 swap and noticed it was off. Many others have said BMW Speedo's and Tach's are all just off. Friend with a E90 his is 7mph off. Eta/M52 is 5mph off.
Old 12-12-2012, 06:11 PM
downhiller's Avatar
livin large
speedo and tach or different. speedo can be anything from tranny gearing to how worn your tires are
tachs are off the pulses to the #1 cylinder, so alot more accurate
Old 12-19-2012, 05:49 AM
Git
I put an S52/ZF 320 in the E30M3. Decided to use a Dakota Digital tach signal converter until I get a six cylinder cluster.
The tach is 50% optimistic at idle and gets worse as the revs go up.
Watching the tach needle slam past 8k and then bounce is just silly.
m
Old 12-22-2012, 06:43 AM
On Top
m
I had the same issue when I swapped my 1.9L Z3 for a 2.8 M52. idle was normal but the revs climbed so fast and the needle flew past 7K. Coupled with loud MAgnaflow exhaust it raised some eyebrows.
Originally Posted by van31 View Post
I dont have the old Tacho, i bought the car and it reads wrong. So you recommend pulling out the cluster and checking?
it's a 323i '85 chassis/motor, but with (what i suspect to be ) a 318i cluster.
It's not that bad, it just looks like i live on the redline..
Late model clusters are backwards compatible throw a moto meter in there from a 87+ 325i and you should be money.
Old 12-12-2012, 11:30 PM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
There are ways & means to calibrate your speedo to be accurate, especially these pulse driven ones
Then your Odometer is usually out afterward
Most Tach's are very accurate untill somebody works them
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 12-16-2012, 05:55 AM
So they are the pulse powered types? Tacho* not taco.. i guess i was hungry.
Old 12-19-2012, 02:12 AM
BMW lebanon BMW lebanon is offline
///323i
Mein Auto: 1985 323i racing
i had this problem when i changed the speedometer. the rpm would go up to 3000 when it should be 2000. so it turns out the chip on the bottom right (the white part that Ethrty-Andy is talking about) had to be changed.
the 4 cylinder one has "003" written on it. you need to get the 6 cylinder one that has "002" instead and it should work.
