X5 E53 (1999 - 2006)
The X5 SAV Forum |
key lock system
Hi,
I am facing a problem with key lock system for X5 2003 . As my new key cant be programmed to open door and back door using key buttons in the key. I had to replace some parts of key control system part located under steering wheel, and part located in the a box top left of the engine . My car is European standard, and two new used parts are US standard, as they have been removed from a used car. Even it is not possible to program old key just to be used to open doo remotely and open back door. Really I appreciate any help regarding above. Regards, |
What RF (radio frequency) is your new key or parts? You mention something about parts coming from a US vehicle...if so...the US BMWs communicate over the 315 MHz RF signal...whereas European BMWs use the 413 MHz RF signal.
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
Thanks for your reply.
I am not sure about RF, but i think it is 315 MHz, as new parts are taken from US BMW car. Which parts in the car affects operations for buttons on the car key? as I did not change all parts related to key lock system. |
FZV & DWA (central locking/anti-theft alarm siren systems) Info
The remote keys contain 3 different technologies (EWS/FZV/DWA) which work in conjunction with each other. The problems you describe sounds like you're having issues with FZV & DWA.
Here's a link to a BMW Technical document (PDF) that goes into detail about FZV (central locking system) as well as DWA (anti-theft alarm siren system) in way more details than I can write...maybe it can help explain some of the issues you are having: http://www.bmwmotorsports.org/BMW_do...lectronics.pdf
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 12-11-2012 at 12:15 PM. |
