Old 12-12-2012, 08:42 AM
ciborgman ciborgman is offline
Mein Auto: 2002, 325I
335I Burnout light code on the dashboard
I have a 335I 2007, that light that tells me that I have a light bulb out came on, I juts checked all over and there is not light bulb broken, is this a known issue. Do I have an electrical problem?
last time that the light came on I ended up replacing the battery, about a month ago. it started with the and then escalated to the point of not been able to start the car.
Anyone?
Cyb
Old 12-12-2012, 09:04 AM
OptionsTrdr OptionsTrdr is offline
Mein Auto: 335is
Double-check your brake lights. There are two bulbs that light up the standard brake lights (I'm not talking about the ones that come on when you brake hard), and it can be difficult to tell if only one of them is out. I missed it the first couple times when my "bulb out" warning came on. My dad was the one to notice it when he was driving behind me one night.
Old 12-12-2012, 04:41 PM
andrew b's Avatar
andrew b andrew b is offline
flâneur en cabriolet
Mein Auto: 2007 E93 N54
Also check the license plate lights.
If you search, I posted a link a while back to a site that has the individual codes for every user message - it will tell you exactly what bulb the system thinks is out. Don't have my favorites right now or would post again.
Old 12-12-2012, 05:36 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
Problems in the rear light sockets can also cause this, even if the bulb is lighting. http://www.bimmerfest.com/forums/sho...6&postcount=12
The page with the code explanation Andrew mentioned is here: http://www.endtuning.com/ccidcodes.html
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 12-13-2012, 07:37 AM
Mein Auto: 335is
Yeah, when my brake light was out it was actually a bad connection point in the taillight housing (the black part that holds all the bulbs).
Oddly enough, my dealership sold the individual bulbs for about $8 each, but the entire housing with each bulb already in it (5 bulbs I think) was only about $20.
Old 12-13-2012, 10:40 AM
The cod is CC ID 136 and is not listed on that list, the manual says is a light in the back brake, maybe is the housing itself, I do like the old style on previous model it tell you exactly where is the faulty bulb with a picture. at least that way I know where to look.
Old 12-13-2012, 01:00 PM
Mein Auto: 335is
Well it sounds like you've narrowed it down pretty well. How are you checking your brake lights? Are you just having someone press the brake pedal while stationary?
Again, check your standard brake lights to see if one of the two bulbs is out. One bulb still provides a good amount of light so it can be difficult to spot. Also, take the car out with someone driving behind you, get up to speed and then let the brakes have it. The person driving behind you should see the additional brake lights come on under hard braking.
Once you've found the bulb then you can determine whether you need to replace a single bulb or if a connection point is bad and you need to replace the housing.
As I said, neither solution is very expensive. It's just a matter of hunting down that one bad light.
Old 12-13-2012, 09:10 PM
I found the culprit, one of the light bulbs was out, thanks for the advice
