E36 (1991 - 1999)
Old 12-12-2012, 08:39 PM
cjk999ca cjk999ca is offline
Mein Auto: 325i
Installation of ignition switch in 1993 E36 sedan
I had an issue with the car not starting but power remaining on. After replacing the original ignition switch I can now start the switch with a screw driver and car functions fine.
However, I am having a difficult time mating the ignitin switch with the tumbler in the column. Unfortunately a mechanic who worked in the area before broke off one of the rabbit ears that holds one of the grub screws which holds the switch in. When I dismantled the original switch, it was held in by one grub screw and two twist ties.
Is there a particular tool to use or position of the male portion of the tumbler (if that's the right term) to get the ignition switch to mate with the tumbler/ignition assembly? I'm lining up the appropriate "male and female" portions of the respective parts but can't get them to mate so-to speak. Any help is greatly appreciated!
ignition switch, installation instruction
