Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E46 M3 (2001-2006)
E46 M3 (2001-2006)
Old 12-13-2012, 05:38 PM
ModBargains III ModBargains III is offline
Mein Auto: E92, E82, E46, E39
ModBargains.com | Ohlins Road & Track Coilovers FINALLY Released For E46 M3!!
Well if you've heard the rumors, they are true, Ohlins Road&Track coilovers have finally been released for E46 M3. I've got some great information for you guys to check out:
Ron, the Ohlins crew and myself!
Picture above is for BMW 1 Series
Of course what we do know is that we should see the same quality that Ohlins has given us for years, with features and benefits, including the following:
Adjustable ride Height
Corrosion resistant construction
Improved handling and braking
Driver tunable shocks
Patented heat dissipation technology
Includes all hardware necessary
2 Year Limited Warranty
Many suspension companies claim to be the best in the world, but have no proof to back their claims up. Ohlins Suspension has won over 200 World Titles in numerous 2-wheel and 4-wheel motorsports. They are the motorsports teams' suspension of choice being involved in many high-level motorsports such as WRC, Touring Cars, the Indy 500, and World Superbikes. Many of the teams using Ohlins Suspenion have consistently made thousands of podiums proving that they are the best in the world. Ohlins Suspension brings this winning suspension technology to their Road & Track Coilovers to ensure that you are getting only the very best for your performance vehicle.
This is the latest step in the Ohlins Racing automotive philosophy – Road&Track by Ohlins. A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over!
Ohlins has added a clever light-weight design with a majority of the parts in aluminum. On top of that, all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide.
The Features of DFV Technology
So what is DFV? It is Dual Flow Valve technology – and it sets us apart from our competitors. Only Ohlins has DFV technology on its road and track products.
With DFV, the dual flow valve gives the same characteristics on rebound as it does on compression, thanks to the damper fluid having a consistent path of flow in both directions. This means that the wheel and tire can quickly and effectively resume their important position back on the ground, providing grip and traction. The new Öhlins R&T range uses DFV technology on every single fitment, making it the perfect upgrade for the enthusiast that needs comfort and agility in the one unit.
Figure 1: (Compression flow) At low shaft speeds, oil flows mostly through the shaft jet bleed (lower dotted arrow). At higher shaft speeds, oil flows mostly through the compression ports in the piston (upper dotted arrow). At very high shaft speeds, or during sudden shaft accelerations, oil can also escape through the compression ports in the DFV, increasing comfort. Figure 2: (Rebound flow) At low shaft speeds, oil flows mostly through the shaft jet bleed (lower dotted arrow). At higher shaft speeds, oil flows mostly through the rebound ports in the piston (upper dotted arrow). At very high shaft speeds, or during sudden shaft accelerations, oil can also escape through the rebound ports in the DFV, maintaining tire contact with the road.
Because DFV opens more quickly and easily on minor road imperfections, ride comfort is surprisingly supple and more akin to an OEM strut than a coilover set-up. Over undulating surfaces, the compliancy of the R&T units allows the car to crest bumps and pot-holes, whilst still keep stable and in control. Traction is always maintained at its optimum level. When comparing suspension, why settle for second best?
Figure 3: (Vehicle – no DFV) Without DFV the oil can not flow through the piston quickly enough on the rebound stroke after hitting a bump, so the tyre is not able to stay in contact with the road.
Figure 4: (Vehicle – DFV technique) The DFV valve opens, letting the oil flow quicker through the piston on the rebound stroke after hitting a bump, enabling the tyre to stay in contact with the road.
When adjusting ride height on coilover units, it's worth comparing how it's done. On many inferior designs, height is adjusted by raising or lowering the lower spring platform. This has the effect of compressing or extending the spring, which can limit the suspension travel that may cause topping out. The Öhlins method is to leave the spring seat in its perfect position, whilst the lower flange spins easily on the threaded body, to allow you to adjust with absolute precision whilst maintaining the perfect characteristics that we took so long to design in! Once you've set it all up, the adjuster simply locks off to maintain your exact settings.
Dampers will get hot. That's one thing that you can be sure of. As the piston moves within the damper, it generates friction – and therefore, heat. Although we can't stop heat, we can deal with it, and this is yet another way that Öhlins differs from the competition. As the heat increases, the viscosity of the damper fluid can change, altering the car's handling characteristics. Our unique needle bleed valve expands with temperature, closing the gap that the fluid travels through, maintaining a consistent damping rate. The best thing of all? You won't even notice! All you'll feel is that the car responds consistently, lap after lap, turn after turn. Allowing you to concentrate on braking points and apexes whilst the Öhlins technology takes care of the damping.
Figure 5: Thermal Expansion
These kits all work well 'out of the box', but there's still plenty of adjustment for you to set things your way. You like stiff and reactive? Or soft and forgiving? It's all there. Too much low speed rebound damping can have an adverse effect on grip, so the easily accessible adjuster at the base of the Öhlins units allows small, but positive increments of fine tuning, so you can take into account every single parameter. Sounds complicated? Nothing could be further for the truth. Just a few clicks either way from our factory settings will soon have your car responding precisely to your inputs and driving style.
The Road & Track McPherson struts also feature camber adjustable upper and lower mounts to give you the possibility to fine tune your wheels for the right occasion – whether you want to go for a ride in your neighborhood or take your car for a spin at the track on a weekend.
Features
- DFV (Dual Flow Valve)
- Adjustable ride-height
- Fully rebuild-able
- Corrosion salt spray tested (ISO 9227)
- Includes hardware and installation instructions
- 2 year Limited Warranty
Front
- McPherson Strut
- Single bleed adjuster
- Spring preload adjuster (approx. 15 mm lower than standard)
- Coil Springs (400lbs/in)
- Dustcovers
- Uses original top mounts
Rear
- Conventional Shock Absorber
- Separate spring preload adjuster (approx. 15 mm lower than standard)
- Coil Springs (630lbs/in)
- Dust covers
Applications
2000-2006 BMW E46 M3
Time to get excited!!!
Sean Singh | Modification Expert | Sean@modbargains.com | (714) 582-3330 ext. 8009
BMW Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | KW Coilovers |
AE Performance | Remus Exhaust | BMW Performance Exhaust
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm (PST)
Check out the Blog!
Old 12-14-2012, 09:14 AM
Got some nice and pretty pictures for you guys too These are the actual parts from the E46 M3 kit:
Enjoy!
Check out the Blog!
Old 01-09-2013, 05:06 PM
bavspeed bavspeed is offline
Mein Auto: 2011 335d / 2003 M3
Very nice!
Do you have anything for a 2006 e60 530i that has OEM Sport Package?
I've had the car since new and my wife drives it, but given that it's now 7 it might be a good time to upgrade, but with more of a separate struts/springs conventional type suspension. I like the engineering you put into this....
Old 01-09-2013, 05:20 PM
Originally Posted by bavspeed View Post
Very nice!
Not Ohlins, but I do have another option that might suit you better. Check your inbox, a message is coming your way!
Check out the Blog!
