E36 (1991 - 1999)
Old 12-13-2012, 06:36 PM
hiroshima hiroshima is offline
Mein Auto: e36 325is
mil. code 1222
I'm sure this has been covered numerous times, the searching I've found has pointed to looking for a vacum leak. My question being, is the mpg guage vacum operated? My girlfriend took my car to work and called saying the mpg guage was not working and the check engine light was on. I stopped on my way home from work and swapped cars. I did the stomp test and got 1222. I reset it and drove home, the mpg guage was working fine, the light did not return. I pulled up to my house, shut the car off and now it is out of gas, I believe...
Old 12-13-2012, 07:36 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
http://www.bimmerfest.com/forums/sho...d.php?t=648187
You canít spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 12-13-2012, 07:54 PM
I read that one. I was wondering if there was any correlation between the mpg guage not working and the 1222 code. I figured if it was vacum operated then it may be leaking and causing the engine to go lean and throwing the code. I know on a maf car a vacum leak will cause a lean condition. On a map sensor car, like a Honda, a vacum leak will make it run rich. I put a couple gallons of gas in it and it started back up fine. I'll check it tomorrow after work and see if a can of carb cleaner can find any vacum leaks.
Old 12-13-2012, 08:02 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
1222 is o2 sensors...
Try changing out the o2 sensor(s) and see if that helps...
Instagram | @randytheus
Old 12-13-2012, 08:08 PM
TRaV MaNN's Avatar
Mein Auto: EW/// 86
Porbably right. Check all hoses, especially the intake boot for cracks.
:3
