Old 12-17-2012, 09:24 AM
Brando7 Brando7 is offline
Mein Auto: 2000 328ci
need advise, 2008 X5 trany problem
hello,
Just bought a used 2008 X5 3.0si 65,000mi from a used car lot. I have been driving it for a week and everything was fine until I took it for a 2 hr ride on the highway. I was accelerating (not aggressively) and the transmission down shifted abruptly and an error message on the screen telling me "transmission malfunction, reduced acceleration, go to nearest BMW service center". I shut the car off to clear it and attempted to drive back home, 10 mins later it happened again.
X5 is now at a transmission shop provided by the used car company I bought it from. He can't
find error codes, and has been driving to see if the problem will show again.
Does anybody have an idea to what this might be? Has anybody experienced this in their early e70 X5?
Old 12-17-2012, 10:36 AM
Yellowm3 Yellowm3 is offline
Mein Auto: BMW
I'm by no means an expert so take this for what it's worth...
Anyone who works on BMW's should be able to retrieve any fault codes/warnings that the car has "barked" at you. If the transmission shop can't retrieve these then I'd have it taken to the stealership if there's no indy around you.
Old 12-17-2012, 10:53 AM
Yeah That's what I thought. There should be a code! I'm thinking the used car dealer just doesn't want to pay.
Old 12-17-2012, 03:58 PM
ard ard is online now
Resident Curmudgeon
There will be a code, but they need a system that has BMW-specific software. A standard OBD reader will NOT suffice.
If at all possible, I would get out from under that car.... the odds of this becoming a BIG situation are large. Even if this costs you $500, I'd get out.
Old 12-17-2012, 04:15 PM
What information are you basing this on? Have you or any others encountered problems like this.
The mechanic is now going to test each gear with a reader. If that does't fix it he will reflash the cpu software.
Old 12-17-2012, 06:56 PM
Resident Curmudgeon
I am basing that on my meager knowledge of BMWs. The car should not go into failsafe mode for 'no reason'...there will be a fault code.
Dollars to donuts he will reset it and give it back to you. Try and get you to keep it until the dealer can blow you off. Dealer is paying this guy, right? Probably the shop that does all the work for the used car lot?
I'd bring it to a BMW dealer, spend the $$$ and get a real diagnosis: if the BMW dealer says "car is fine, we cant explain it", then you are as good as you can get. But if the BMW dealer sees issues, NOW is the time to press your case.
Penny wise, pound foolish?
GL
Old 12-17-2012, 07:17 PM
GL
Good point. also if cpu is reset will that clear all fault codes?
thanks for you input
Old 12-17-2012, 07:47 PM
Resident Curmudgeon
"reset" isn't a complete description. A power down, reset all adaptive values, etc, should not erase the historical fault code reporting. But I am not sure. I dont have any experience with E70s, just older E39s. I guess there may be a way to 'reset the cpu' such that you lose the info.
The challenge for you, IMO, is to quickly figure out if you were sold a car with an existing (and perhaps known) defect... I would not be allowing the 'team' that possibly patched this up and sold it to you, to mess with it and maybe slip it back to you.
Perhaps this dealer had a tranny fault, took it to the mechanic, and the mechanic 'fixed' it and gave it to the dealer with "Its ready to sell". Now, two weeks, and the same fault. Dealer is telling the mechanic "you need to figure this out, you told me it was fine".....
I'm wildly speculating here, but as long as you are bringing it to the dealers' mechanic, assume everything he says is...well... lets say 'maybe not the whole truth".
Also, you bought this 'as is' right? Why ARE they helping out?? Just a solid, ethical used car lot?? I am so damn jaded.....
A
Old 12-18-2012, 08:17 AM
A
The Mechanic is not part of the used car dealer, but I'm sure they're friends. Bought the car with 2500mi or 60 day warranty. they are paying for everything. If the problem persists they will buy back the car.
I am really frustrated with BMW right now, I'm thinking the only good BMW's are manual trans.
Old 12-18-2012, 09:55 AM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
FWIW, that is the opinion of Mike Miller, the BMW CCA Roundel magazine Technical editor.
Old 12-18-2012, 11:50 AM
Resident Curmudgeon
You bought a used car with a bad transmission and you are 'frustrated with BMW'?!??!
Old 12-22-2012, 09:30 AM
Resident Curmudgeon
just another thought: my fear would be that they mess with it enough to make it work OK for 60 days or 2500 miles, and THEN you will be SOL.
Here's a potential conversation:
Mechanic: "This thing really needs a remanned tranny, going to cost $8000.
Dealer: "Can we just buy a filter kit, you drop the valve body, give it a cleaning and fresh fluid and lets see if we can get it going for a while- I'll pay you 4 hours of labor, plus parts- lets say $800"
\Mechanic: "sure, your call"
OP- GL
A
Old 12-23-2012, 06:46 AM
Chucktown Chucktown is offline
Mein Auto: 2012 Audi A6
How has this thread lasted for so long without some reference to the other "tranny?"
Old 12-28-2012, 02:11 PM
Resident Curmudgeon
Are you communicating directly with the BMW dealership??????? You own the car, the used car lot has no 'legal standing' to permit work to be done or even to have the car touched by the dealership. (They may not even know this, they may think it still belongs to the lot...)
I'd make sure they are doing a full and complete job- new trans, new torque converter, etc. With a written warranty (ie Work Order) IN YOUR NAME.
I'd be OK with an all new BMW remanned tranny with the two year BMW-backed warranty.
You're lucky
A
Old 12-28-2012, 04:20 PM
You're lucky
A
Yes I've talked with the BMW dealership. The contract states that the used lot is required to fix the vehicle, actually BMW told me they didn't even need to talk to me...go figure. I don't know the legal aspect of this, but I think it is all under the lemon law.
Yeah good idea, don't want a salvaged trany or refurbished. I don't know yet who is doing the install, I hope BMW.
Old 12-28-2012, 05:51 PM
Resident Curmudgeon
Full stop.
Id give them the car back ASAP.
There is ZERO chance I would accept anything other that a BMW remanned and BMW install...IN MY NAME.
"Hope"?!??! OMG.
Old 12-28-2012, 08:31 PM
soldmystang's Avatar
soldmystang soldmystang is offline
Mein Auto: e70, e36, e90, e46iT, 6.0
Careful what you wish for OP, you just might get it.
Don't walk...... run away.
Old 12-31-2012, 03:01 PM
Dealer got back to me and unfortunately he put in a used transmission with 50k miles on it.
He told me a new trany installed by BMW would run about $10k.
I've decided to dump this car and get my money back, which he has agreed.
I'm now looking at a lexus RX-something.
Old 12-31-2012, 05:09 PM
henrycyao henrycyao is offline
Mein Auto: BMW X5 35d
That is pretty drastic jump from BMW. Any reason why not Acura? Their older RDX with sh-AWD is supposed to be sporty. It has better AWD performance than Lexus.
Sent from my LG-P999 using Bimmer App
2012 BMW X5 Vermilion Red Xdrive35d with Premium Package, 3rd Row Seats, and Adaptive Drive
Old 12-31-2012, 05:32 PM
I've had Acuras and Hondas and they can't make an auto transmission to save their life either. I looked at the MDX, its nice, I just don't care for the look of the front end.
Has anybody heard good things about the Audi Q7?
Old 12-31-2012, 06:08 PM
Audi has a very nice AWD. I highly recommend it if sporty is not a high priority. It is not as sporty as BMW X5. In Audi case, you really need to research on carbon build up. I know the new supercharged 3L are very good and seemed to resolve the problem that started in 2011 model year. You will need to look up the older 3.6L for yourself to see if it has the same problem.
Older Porsche Cayenne is supposed to be better than BMW in reliability. That is something to consider.
Honda had a problem with their transmission due loading problem on their heavier cars like oddessy. It has since then been resolved as far as I can tell. That was an early 2000 problem if I recall.
Personally, I would give BMW X5 another try.
transmission x5 e70
