Newbie with IS issue - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 12-18-2012, 02:26 AM
shanto shanto is offline
Mein Auto: 318i
hi everyone,
this is my first post on this forum. ill just intro the ladies.
i have two beautiful but rusty beauties at home.
one bronze 318 2 door and the other is a white 318IS.
i just bought the IS a week ago.
its not at the moment. The guy i bought it from dont know why the engines is not running so he got rid of it.
She (white one) is a pretty rough state now. I'm still a newbie so i have no idea to diagnose the symptoms. When started, the engine turns over and it is followed with a CLUNK and it shuts off.
One of my friend told me its either something minor or major issue which wasnt any help at all. LOL. some friend i got....
If anyone can assist me with this or have any thoughts, I'd be privileged....
Looking forward for replies.
Cheers
Old 12-18-2012, 03:19 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
Really need more info then that.
Old 12-18-2012, 04:20 PM
downhiller's Avatar
livin large
check compression first off
Old 12-18-2012, 07:45 PM
BMWFatherFigure's Avatar
Old School
Plugs out and turn engine by hand a few revs. Then you would get a feel for any valves vs piston problems. Then compression check dry and wet - then got back to us..
Current:
E38 Parts Car
Previous:
Old 12-19-2012, 01:29 AM
Mein Auto: 318i
Should I turn the ignition on?
Old 12-19-2012, 01:36 AM
hornhospital's Avatar
D'oh, You Kids!
No
Sent from my MB860 using Bimmer App
Quotes to live by:
BMW-CCA #441426
Old 12-21-2012, 04:18 PM
Mein Auto: 318i
Most probably broken piston bearing. Taking up the DIY. Any advice?
Old 12-22-2012, 07:42 AM
downhiller's Avatar
livin large
pistons dont have bearings. i would start watching alot of horsepowertv on spiketv.com under powerblock.
Old 01-19-2013, 11:50 PM
Mein Auto: 318i
Just drained the oil. The bottom of the pan had metal filings. No chunks.
What's next to do?
Old 01-20-2013, 12:00 AM
Mein Auto: 318i
Just drained the oil and found metal filings.
No compression test done.
Opened the cover and the plastic next to the timing chain has slightly damaged.
Right amount of oil inside it when drained.
The air intake hose was damaged.
What's next?
Should I still do compression test?
Old 01-20-2013, 02:21 AM
Old School
Read my words - IF if does not clunk when turned over by hand do a compression check wet and dry. Metal shavings in the oil not a good sign. Engine could be very dead.
Current:
E38 Parts Car
Previous:
Old 01-31-2013, 12:47 AM
Mein Auto: 318i
Compression is 13.5 bar. It turns over nice but backfires every time I don't leave the throttle open.
There is sparks.
Wires are plugged properly to the distributor.
Need more help...
Old 01-31-2013, 12:57 AM
Mein Auto: 318i
Btw. The timing was off and my mate helped me out in position before compression test.
Old 01-31-2013, 07:01 PM
downhiller's Avatar
livin large
if its backfiring, you could have cylinder unloading. running rich so one power stroke the spark is put out, but on the second one, it lights causing backfire. which if thats the case, fuel pressure test
