Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 12-18-2012, 01:36 PM
BMWZ4RIDER BMWZ4RIDER is offline
Z4 35i Rider
Mein Auto: 2009 Z4 35i
Easy and In Expensive Projects
1. LED Interior Lamps-. Just finished my LED Interior lamp upgrade. I used the Phillips T10 X Treme Vision 6000K, 1 watt LED lamps. I replaced the 3 domes, 2 footwell, 2 puddle and 1 trunk lamps. I loved the new higher light output but knew it could be brighter for the footwell, puddle and trunk lamps. I removed the 6, brown, plastic lamp housings and lined them with Heavy Duty Aluminum Foil (Reynolds wrap). This provides a highly reflective, heat resistant, easy to install, bright reflector surface for the highest light output possible and easy to replace and or remove for the smallest cost possibe. These lamps as well are only 1 watt and produce only 1 watt of heat vs the standard 5 watt glass jacketed W5W lamps. Light output is at least 20% higher.
2. BMW (metal) Logo Valve Stem Caps- No biggie, but on this site and I was told direct from BMW to not install them in metal. Reasons: The metal caps can weld themselves on the stems 2. BMW states possible interference with the TPMS with error messages.
To solve both issues, I wrapped the valve stem threads with teflon tap, therefore creating a gap and a non metal to metal surface of the cap to the valve stem threads.
3. Aluminum Pedal Set (3) Installed- Throttle, Brake and Dead Pedal. I gambled with my order on EBay, from a company called DDC located in China for $34.97 SHIPPED. They arrived in 10 days from China, by USPS. I paid with Paypal.
Throttle- I clamped the pedal onto the plastic OEM pedal. I carefully marked the mounting holes and drilled only 1 hole at a time and installed each screw after drilling, to ensure perfect fit. I used appx 1/2 inch, very small phillips SS screws. For the ease of install, I unbolted the Allen bolt on the base of the pedal and removed it from the upper metal frame but left it installed ( as I could get the wire connector off). This gave enough slack in the wire to get the needed clearance for the drill and install.
Brake- Remove the rubber pad on the pedal and install in the same format as above except mounting with the Allen botls and lock nuts provided. Be care to measure many times before drilling and mounting, to get it centered. There is very little room for error on the pedal.
Dead Pedal- Ths pedal did not cover 100% of the OEM plastic, but who is going to know and for the price and quality, I am very happy.
I did not want to drill holes on the floor pan, wheel well to have possible water intrusion, so as I did with my former Acura, I installed the dead pedal with Industrial Strength Velcro. I hot glued the rubber insert pad to the Aluminum pedal frame.
I cut the screw heads off the SS screws and hot glued them into the mounting holes so it looked like it is screwed on. I cut the Velcro to size and to cover the complete pedal except for a 1/4 gap around the outer edge of the pedal. Before installing the Velcro, I used my heat gun and heated the Velcro to kick start the glue and then heated the plastic dead pedal. I installed the Velcro, both sides on the pedal and removed the backing side which mounts onto the plastic dead pedal, so there was no need to try to match up the 2 sides. Once heated and installed, I used my foot for full pressure. Clean, easy and inexpensive.
Name:	LED Puddle lamps.jpg
ID:	353701   Click image for larger version
Name:	Lamp housing Reflector &  Phillips LED lamps.jpg
ID:	353699   Click image for larger version
Name:	LED Foot well  Lamp Installed.jpg
ID:	353700   Click image for larger version
Name:	Lamp housing reflector 1.jpg
ID:	353698   Click image for larger version
Name:	2012-12-13 09.58.15.jpg
Name:	OEM Standard foot well lamps.jpg
ID:	353696   Click image for larger version
Name:	Z floor well lamsp housing.jpg
ID:	353695   Click image for larger version
Name:	LED Interior.jpg
ID:	353702   Click image for larger version
Name:	LED Trunk lamp.jpg
ID:	353703   Click image for larger version
Name:	Z OEM Pedals.jpg
Name:	New Aluminum Pedal SAet 12-17-12.jpg
ID:	353705   Click image for larger version
Name:	New Aluminum Pedal set 2.jpg
2009 BMW Z4 35i/Space Gray Metallic/7 Speed DCT/Premium,Cold Weather & Premium Sound Packages/Nav/Comfort Access/Ash Grain Interior & Dash Kit/AntiTheft/SportWheel/PDC/WindDeflector/Black Kansas Leather/Smoked Reflectors, Side Markers & 3rd Brake Light/Ferrari Red Brake Calipers/Clear Front Mask/Gloss Black Grill Inserts/6000K LED Lighting/De-Badged/Aluminum Pedal Set/Real Carbon Fiber BMW Door Sills/CF Wrapped Engine Compartment Roundels,F Lower Grills & Center Wheel Caps.
Old 12-19-2012, 05:44 AM
Carl3 Carl3 is offline
Mein Auto: BMW
$35?.. Nice!
