Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 12-19-2012, 04:02 PM
James's Avatar
James James is offline
Mein Auto: E36 M3
Need to Disconnect battery for a few seconds to start...
Tried searching the interweb for this issue but couldn't find anything. If this is covered in another thread please point me in the right direction.
Car: 1995 E36 M3 with ~130K miles.
The Issue:
Randomly and occasionally (sometimes twice in one day and then weeks without the issue) I turn the key to start the car and it loses all power instantly. No noise, just a small sound like turning the car off from key position 2. The car in this state is now dead to the world: No lights, windows, door locks or window drop (that 1/4inch thing when you open the door on a coupe). I disconnect the battery for about five to 10 seconds and then reconnect the battery and try again and she fires right up strongly like nothing was ever wrong.
Notes: This seems to happen regardless of if the car has been sitting for a day or so or just driven for an hour. So each time I go to start the car it's a bit of a crap shoot. The battery reset trick has worked every time so far.
My thoughts are one or both of the following:
1) Bad ground somewhere shorting out the computer
2) Relay going bad and becoming flaky
Thoughts? Ideas to diagnose? Although I have a good shop in town that works on my car I am hesitant to take them an issue that is so sporadic. If I can find a way to replicate it reliably I'd have something to take them or could fix it myself if it's shade tree mechanic doable.
Thanks!
James.
It is impossible to enjoy idling thoroughly unless one has plenty of work to do. - Jerome K. Jerome
Old 12-20-2012, 10:55 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
This is really odd. I'd suggest reposting in the regular e36 section.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 12-20-2012, 01:22 PM
James's Avatar
Mein Auto: E36 M3
Thanks petriej. I searched the E36 forum and found a couple people with similar issues and they were pointed to check the chassis grounds. I'll check on that before I repost.
James.
Old 01-10-2013, 09:08 AM
The G.O.A.T. The G.O.A.T. is offline
Mein Auto: 1989 325si
I've had the same problem on many cars of mine, for me it was always the battery terminals (on the battery or on the car) and the fix was a good cleaning. (baking soda and water works for me)
Good luck,
Nick
Old 03-03-2013, 02:04 PM
Bassle Bassle is offline
Mein Auto: E36 M3
I can just about promise you your problem is a loose connection at your battery terminals. Sometimes you can just clean and tighten them really well, but other times they may be cracked or worn badly enough that they can't be tightened sufficiently enough to make a proper connection. Try cleaning and tightening them with proper tools of course, and if that dosn't work just replace them.
