Tpm? - Bimmerfest - BMW Forums
Old 12-23-2012, 10:03 PM
roseng's Avatar
roseng roseng is offline
Tpm?
I am getting a TPM error even after resets. All pressures are correct. I assume I have a bad sensor. How do you tell what wheels are working and how do you test these transmitters?
Old 12-24-2012, 12:32 AM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
That's strange, I thought all e63 had the RPA system? This system does not have its own sensors but relies on measurements from each wheel speed sensor from the ABS system. It can determine a change in rolling radius from this & therefore flag this change as a drop in tyre pressure.
During the calibration stage it takes measurements at different speeds, as the diameter will be different as the speed of the car changes. That is why you see the system message "initialising" when you first reset it iDrive.
Have you reset it since you fitted your new M6 wheels? It's under "i" -> "Vehicle Settings" -> "RPA". You must do this after any change in tyre or top up of tyre pressure.
(Tyre = tire)
Old 12-24-2012, 06:52 AM
roseng's Avatar
(Tyre = tire)
Thanks but no, it's a TPM system with sensor in each wheel valve. At least on the '07 I have. Maybe late models are different.
Old 12-24-2012, 07:09 AM
645/333's Avatar
645/333 645/333 is offline
Michael
+1 on checking codes first before looking at each sensor, if my understanding is correct this is built into the wheel and given you bought these wheels after they were chromed you may have duff sensor???? It is not uncommon !!!
Old 12-24-2012, 10:19 AM
roseng's Avatar
No, these are not built into the wheels. They are separate sensors that mount in the wheels. Here is the detail on the parts, #1 and 2.
Old 12-24-2012, 05:02 PM
HerbP HerbP is offline
Did this happen after you changed your wheels?
Old 12-24-2012, 03:45 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
Roseng -You have a DIS/NCS setup don't you? Connect to DIS and see if you're getting any faults in the system. RRanter is pretty knowledgable with the PC stuff maybe he can point you in the right direction. I'm going into the office for a little while this a.m., but I'll plug into mine when I get home.
M6 bumpers, skirts & wheels
HUD, Comfort Access
Old 12-24-2012, 06:50 AM
roseng's Avatar
Good thought. I'll give it a shot and see if I can tell anything.
Old 12-24-2012, 09:39 AM
coug60's Avatar
coug60 coug60 is offline
06 BMW 650i Sprt/Prem Pkg
Mein Auto: 2006 BMW 650i e64
On the TPM system doesn't it give you psi for each tire? On my 7 series it did. You should just be able to look at the affected tire in the system. If you aren't maybe the TPM receiver is bad...
+ Various Mods & Upgrades
Old 12-25-2012, 08:43 AM
colink colink is offline
Mein Auto: 2004 645Ci Convertible
Wink
"Same sensors, same tires, new wheels same but size."
Freudian slip or a Christmas Bangle?
I hope you get a resolution for Christmas Roseng.
Old 12-25-2012, 10:08 AM
roseng's Avatar
Oops, too much egg nog!
It is the same size wheels.
Thanks for the XMAS wishes, not sure how I can unwrap it though
Old 12-25-2012, 11:04 PM
roseng's Avatar
Well Colink,
Your wishes may have worked. Kind of bizarre but I ran out to the store today and on the way there no change and same errors. When I came back suddenly and for no apparent reason, all was ok and no errors.
We'll see what happens tomorrow.
Old 12-28-2012, 01:21 PM
roseng's Avatar
Well Colink,
Well not surprising, it's back I have an appt. with my local shop next week. He thinks it may be one of the sensors.
Old 12-26-2012, 06:16 AM
I wish, I wish for a new M6 for everyone on the list!
Old 12-26-2012, 06:57 AM
roseng's Avatar
Now I'm going to have to come to Oklahoma and buy you a beer.
