My car sounds like a airplane
I wanted to see if anybody had the same problem or can help me out with my problem my car sounds like an airplane when I'm hitting the gas and it feels really heavy
Sent from my LG-MS695 using Bimmer App |
Clutch fan? Are you talking about the wooshing shound on take off?
![]() Touring the nation, one state at a time |
It could be your driveshaft about to go. I had that problem on my old car. You can still drive but not far before it goes out.
it's more like a humming sound
not only take off but it sounds louder on takeoff
Thank u
Strange. The driveshaft is a little louder than just a hum so maybe not that. I'm not sure what to tell you.
Does the sound only come on when ur AC or Heat is on? Because mine does that same sound but only when those are on.
Sent from my PG86100 using Bimmer App
There are two main causes of a loud airplane sound: the secondary air pump (electric) and the engine-driven-though-clutch fan.
The relay may fuse on the secondary air pump and cause it to stay on all the time. Unplug the relay to see if it turns off for diagnostics. It will burn out in short order if left to run all the time. It's only supposed to be on for a minute after a cold start to inject air into the primary cats to heat them up faster. The fan clutch on the front of the engine may sieze up, causing the fan to rotate at water pump speeds all the time. This is even worse as the fan was not meant to go that fast and has been known to explode if it is weak or contacts the shroud due to worn engine mounts. This is easy to identify. At a stop, rev the engine in neutral. If it sounds like it's taking off, then it's this fan and you should change the clutch and fan blades immediately. If it's loud while doing this it also can't be the driveshaft as it isn't moving... |
Thank u so much
Even when the AC is off or heat
Lol its cool thank u
When you perform the above diagnostics please report back with your findings. Same if you find a solution.
This way other new members such as yourself can find help in this thread as you hopefully are. |
no problem will do
could also be your cooling system not doing its job. The car might be running hotter than normal. Check to make sure your coolant level is correct. Any noticable leakage?
[Rebuilt M62TU, Shortshifter & ZHP, Spacers, BC Coilovers, Hawk Pads, Stainless Lines, 20% Tint, & Ebay cupholders. Y Res delete, control arms, bushings, and sways coming soon!] |
Wheel Bearings??
If it were your SAP, it would ONLY last about 90 seconds after a cold start-up. That's
it! If it is possible it is your fan clutch (do search about rolled-up newspaper) your fan blades could come up right through your hood, destroy radiator, and more. At least see if you can easily stop fan blade on a cold start-up in morning with just a small amount of rolled-up newspaper. If you can't stop your fan blade easily right upon cold start-up, your fan clutch is NG. Then you'd be driving with time bomb ticking. Do not race over about 3000 rpm if you find fan blade clutch is shot. |
go to about 3rd page on bimmerforum and read new post called "clutch fan of death" to see what you *might* be up against.
Thank u
sounds like your fan clutch is close to due
