Old 12-27-2012, 01:14 AM
Tejijohal Tejijohal is offline
Mein Auto: Bmw z3
Heater blow cold air and car overheat
Hi all. My z3 1.9 1999 heater blow cold air and also engine overheat when drive slow or in traffic. There is no coolent leak and i bled the system already.
Old 12-27-2012, 03:02 AM
Droptop85 Droptop85 is offline
Mein Auto: 03 Z4 3.0i
Either you have no coolant or your thermostat is stuck shut
Old 12-27-2012, 03:58 AM
Mein Auto: Bmw z3
Thanks for reply. Coolent is full I have checked few times. If there is thermostat problem how do i fix that ? I am wondering if the water pump is working or not
Old 12-27-2012, 04:07 AM
It's hard to say. I would replace te thermastate and thermastate housing before replacing the water pump. Reason being it's cheaper. While the vehicle is running and at operating temp try squeezing your radiator hoses. If they they are super stiff you have built up psi. They should be squeezable while the vehicle is running and at normal operating temp. If not. Thermastate is stuck closed.
Old 12-27-2012, 10:14 AM
Mein Auto: Bmw z3
Thanks for help. I will try that
Old 12-29-2012, 07:10 PM
morrieschoice's Avatar
morrieschoice morrieschoice is offline
Mein Auto: 2001 3.0 Z-3 ROADSTER
overheating
If you decide to replace the thermostat, strongly consider replacing the water pump. Make sure you get one with a metal impeller....(see photo of 'new" pump with composite impeller). This is what caused my car to overheat after replacing the entire cooling system.
ID:	355107   Click image for larger version
Old 12-30-2012, 10:00 AM
dougmcintyre dougmcintyre is offline
formerly updmst
Mein Auto: 2000 M Coupe, 1997 318ti
Does the car have the original cooling system? If yes or unknown, I'd replace every component of that 12+ year old cooling system. The component quality of our cooling systems are, ahh, sketchy.
See
http://www.318ti.org/forum/showthrea...hlight=cooling
http://www.318ti.org/forum/showthread.php?t=18066
