7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code! |
Tranny
What's different with the newer tranny's ? I know the 02-08 are designed to last 80,000 miles (lol). Is BMW still making them.
Repairs 2012 wishbone & steering rack Rfmd hydro steering gea combination nu Ball Joint Tension strut with hydr Switch unit steering column Coils 5&7 and new spark plugs Faulty DSC Control Module Fuel Gauge Leaking Crank Case Vent Valves Power Steering pump, washer pump and grommont, Crank Shaft position sensor Total $13,481.37 in one year my mechanic swears all these parts are re engineered to work better than the originals lol
Or is someone else making the transmissions now?
The newer "Tranny's" have plastic surgery done... Da da dum...
Thank you very much, I'll be here all night, tip jars on the table folks...
2013 740 Li 2007 G35 (trade-in) 2003 Z06 (Black, 50th Anniversary) 2001 Z06 (Torch Red) |
BMW doesn't make their own transmissions, they buy them off the shelf from a company called ZF. ZF makes a multitude of transmissions for tractors to semi's to BMW's! BMW uses their own programming to run the transmission and control it's shifts.
The transmissions are different to an extent depending on your model. The 740's and 750's and B7 from 2009-2012 use the same transmission as the E65/66 from 2002-2008, the 6HP26Z from ZF. The X-drive models use a slightly modified version of the 6HP26 called the 6HP26Z-WHK The Hybrid 7 uses a ZF transmission called the 8HP70H which is an 8 speed transmission with the hybrid motors and such inside. The 760 uses an 8HP90Z transmission which is an 8 speed, but it is built with better components to handle all the torque and power vs the hybrid. EDIT: As far as power ratings for the ZF trans goes heres what I found with a quick search: 8hp30 - 300nm (221 lb-ft) 8hp45 - 450nm (331 lb-ft) 6hp26 - 600nm (442 lb-ft) 8hp70 - 700nm (516 lb-ft) 8hp90 - 900nm (664 lb-ft) Last edited by csmeance; 12-28-2012 at 04:30 PM. |
Awesome, knowledgeable post; thanks.
Lol.
2011 750i |
